BIKELAND > FORUMS > ZX-14.com > Thread: LM1 install NEW TOPIC NEW POLL POST REPLY
06redzx14
posted February 06, 2009 05:21 PM
LM1 install
which wires to get RPM and throttle position? would like to do it close to the ecu
bruno nadeau
posted February 06, 2009 06:13 PM
is it inovate lm1. if it is what do you use for rpm and tps...........rpm converter.aux box ssi4.i can help if i know what you use.lm1 alone cant read rpm tps........
bruno nadeau
06redzx14
posted February 06, 2009 06:20 PM
I have the LMA2(rpm converter)
bruno nadeau
posted February 06, 2009 06:45 PM
on my zx14 i tap the rpm on the negative wire on the coil over plug on the last plug on the right and use the negative and the variable output on the tps sensor on the same side of the engine for the tps.if you realy need to plug near ecu let me know i can tell you the wire i have to look tomorow and give you answer but i never plug there before but i think it is a place you can conect.
bruno nadeau
06redzx14
posted February 06, 2009 06:49 PM
was trying to connect near the back because I have the unit under the seat
bruno nadeau
posted February 06, 2009 06:51 PM
for the rpm you will need a 20 or 50K pot to stabilise rpm
bruno nadeau
bruno nadeau
posted February 06, 2009 06:54 PM
let me look tomorow
bruno nadeau
bruno nadeau
posted February 06, 2009 07:08 PM
go to www.afrtuner.com download user manuel look page 48 49
bruno nadeau
ninja12
posted February 07, 2009 07:36 AM
You can do what you want, but be sure to get the ECU ground also.
I use a auto trailer extention as a quick connect.
Just use the end that stays on the car to stay on the bike.
I pulled mine chasing a electrical grimlin, but I'll look in the manual for
you if nobody else knows.
0.36371207237244 seconds processing time
