BIKELAND > FORUMS > ZX-14.com > Thread: fluid for clutch NEW TOPIC NEW POLL POST REPLY
posted February 05, 2009 06:33 AM
fluid for clutch
guess im gonna go ahead and bleed the clutch fluid out and replace it. what kind of fluid are you guys using?
posted February 05, 2009 06:44 AM
i know its dot4, but if i remember correctly there is synthetic brake fluid, etc...
pissear
Professional Cockis Slap Peer
posted February 05, 2009 10:36 AM
Use plain old Dot4 in a sealed container like the cap says. I just did mine at 4K about. Anything else like syn is overkill. Dump both brake and clutch lines while you are at it. Bleed the left front first. Just open the nipple and pump. Keep the master topped off. Once the brake fluid looks clear, pull the lever and hold; tighten the nipple. Release brake lever and feel the pedal. It should be tight, bubble free and not compress air but fluid. Do the same with the right caliper is leave it open and keep pumping till clear. That press and lock the nipple every time you pump is for squids.
posted February 05, 2009 10:51 AM
use dot4
the dot 5 is not compatible with dot4,
any residual dot 4 will gell with the dot5.
posted December 24, 2009 07:30 AM
Galfer brake fluid
14nooby
posted December 24, 2009 07:33 AM
All DOT 4 is synthetic. DOT 5 is a silicone fluid. Go get some plain DOT 4 and you'll be fine. Why are you changing the fluid? I would leave it alone unless it's black.
posted December 24, 2009 07:35 AM
gravedig lol
Flame On
Fuel Air & Spark
posted December 24, 2009 09:19 AM
Changed mine with auto zone dot 4 brake fluid works fine
77 RD 400
80 GS1000 GT
06 ZX14
68gts2
hobbies ( Beating you !!! )
posted December 24, 2009 11:14 AM
pissear can speak english after all!
That's the only post of pissear's I have ever been able to read without a fuggin headache. Guess that english conversion thing is finally working for him.
Bawls
re-learning to ride
posted December 24, 2009 11:23 AM
lol, naaaaah.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
0.22503018379211 seconds processing time
