BIKELAND > FORUMS > ZX-14.com > Thread: Help 14 wont start NEW TOPIC NEW POLL POST REPLY
BigBoy14
posted January 29, 2009 09:02 PM
Help 14 wont start
First off hello board members. Well a couple of days ago I started her up and while warming she went dead I restarted went riding and she wouldn't start once I shut her down- has new battery engines turns strong but makes no attempt to start has pc3,smeg,bmc fltr-any ideas
SubZer0
posted January 29, 2009 09:09 PM
Bad PC III? Bad Ground for PC III?
Ninja14
posted January 29, 2009 10:12 PM        Edited By: Ninja14 on 30 Jan 2009 06:12
PC ground has been the cause of at lest 5 I've heard about. Under the plastic bottle is a bad idea....use the 8mm cover bolt right below the bottle.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
BigBoy14
posted January 29, 2009 10:59 PM
well make it 6 because my ground wire was practically cut into just spliced it back and she lives again--thanks guys
Ninja14
posted January 29, 2009 11:09 PM
Make sure you move it if it was under the plastic....it may work loose......seen it before.
2006 Turbo ZX-14.
WARBIRD
posted January 30, 2009 09:19 AM
Glad you found the problem. May I suggest you take the time and ground it to the battery? It may save some more headaches in the future. If you have to lengthen the ground wire be sure to make proper terminations. ( good quaity terminations )
I'd Rather Be Roadracing.
0.27418994903564 seconds processing time
