BIKELAND > FORUMS > ZX-14.com > Thread: Who is running the power race soft rear? NEW TOPIC NEW POLL POST REPLY
rACeRs
posted January 26, 2009 09:20 PM
I just added some length and a 180/55 power race soft to my bike. I was wondering what you guys are running for tire pressure. Im at 64" now and a pretty heavy rider. I was going to start with 42psi and start dropping it from there. I see how people are saying these things hook like glue so hopefully I can get away with a lot of psi as to not rob any mph. My track prep is usually pretty good. So what are you guys usually running in these?
thanks
9.1 @ 149 w/ 1.57 60' SWB
posted January 26, 2009 09:26 PM        Edited By: SteveWFL on 27 Jan 2009 05:26
Due to the tire warmers heating the air I only inflate mine to 22-27 PSI depending on weather and which track we're racing (and Michelin saying that the pressure for optimal stick). We're doing a different type of racing, but if this tire is pre-heated to proper temp you won't want that 42 pressure for best stickiness?
rACeRs
posted January 26, 2009 09:29 PM
Right on, good to know. thanks for the reply
rACeRs
posted January 26, 2009 09:31 PM
Ive always wondered if you had tire warmers would you even need to do a burnout? IF so the warmer would pay for itself in no time. And it would be nice not to have to clean all that friggin rubber off the bike. How much do you notice the warmer helping in initial traction?
posted January 26, 2009 09:33 PM
I run 17 PSI in my shinko and i bet money you will have to run close to that to get it to hook ..
rACeRs
posted January 26, 2009 09:37 PM
I will post back and let you guys know what worked for me. This will be my first time on an extended bike, so I really have no idea where to start or what to expect.
posted January 26, 2009 09:47 PM
it'll be interesting to see what you find! I agree with smokin', I strongly suspect you'll find less PSI sticks a lot better than more knowing that tire. Also on hot tracks, I find the power race medium sticks better for me than the power race soft. and that soft is one gummy mo-fo!
posted January 26, 2009 10:21 PM
I was able to hook with about 38-40 degrees air temps at 17-18 psi. You should be able to put at least 22 in it, I would think.
posted January 26, 2009 11:05 PM
i gotta try this tire.... my bike liked 8-10 psi in a u soft(not a great track)
gilberjj
Friend of Fast
posted January 27, 2009 12:03 AM
I got a Dunlop Sportmax gp 211 from a Dunlop rep. He said to run that tire at 18 psi at the drap strip or on a track day (it's a medium compound).
Bently
2012 14r In Blue and no Mods!
posted January 27, 2009 04:01 AM
Well I run the super corsa race which is real similar to the power race and I have no troulbe running 32 psi at 63 inches. Start high and work down. I bet you find at least upper 20's will work. And I barley do a burnout. Way better then my shinko ultra soft ever was. some days I would be down to 8 to 10 psi to get that tire to hook
ninjaboy311
posted January 27, 2009 06:22 AM
I run the Power Race Soft 180-55 also. At 69" wheelbase, I run anywhere from 10 psi-18 psi depending on track conditions. Here's some video I took last week. I had just run my quickest pass ever of 8.745, so I put my buddy on my bike to see what he could do, and so that I could get some video. First pass he went 8.795, and 2nd pass he went 8.746. Air temps were around 40 degrees, and track temps were around 48-50 degrees, and this tire still hooked like glue. Was getting mid-1.30 60 foots all night.
GHOSTMAN
posted January 27, 2009 07:25 AM
Man rACeRs, that's a good question about the tire warmers.
Anybody want to chime in on this one? I'm curious myself.
I'm There Whether You See Me Or Not.
Bawls
re-learning to ride
posted January 27, 2009 07:34 AM
You should e-mail brock davidson and ask him... I know that he runs the same tire on his bikes so I'm sure that he could shed some light on the situation.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted January 27, 2009 07:38 AM
the only difference tire warmers make for me is I can go out immediately on lap one at speed rather than waiting for the tires to warm to proper temp
ninjaboy311
posted January 27, 2009 03:17 PM
If I had to guess, you'll still have to do a burnout...Your tire will cool off from the time you take the warmer off, till the time you launch the bike..and not only that, a burnout gets rid of all the debris you will pick up rollnig through the staging lanes, such as pebbles, sand, grass, etc.
rACeRs
posted January 27, 2009 03:56 PM
True good points.
ninjaboy311
posted January 27, 2009 09:27 PM
One good thing is that the Power Race doesn't need nearly the burnout that the Shinko does...so it does last a very long time.
gilberjj
Friend of Fast
posted January 27, 2009 10:56 PM        Edited By: gilberjj on 28 Jan 2009 06:57
haha..... are you sure that's the correct wording?
I don't know if "last a very long time" and pilot power race soft should be in the same sentence!
ninjaboy311
posted January 27, 2009 11:33 PM
Can't vouch for street use...but as far as drag strip only, they last just as long as a Shinko.
posted January 28, 2009 11:51 AM
rACeRs, don't forget that you will be giving up some gearing with the tall tire. Compared to a Shinko 190, it is about a whole tooth.
0.53008699417114 seconds processing time
