BIKELAND > FORUMS > ZX-14.com > Thread: Cheap front wheel tool NEW TOPIC NEW POLL POST REPLY
3000psi and falling
posted January 26, 2009 03:43 PM
I just ran to the hardware store and made my own front axle removal tool. After going to napa first only to find that plug socket #NTD626S that lots of guys use for this has changed?? and will no longer fit the axle. So I found that a M14 bolt and 2 M14 nuts and a lock washer work just fine. Only cost $3.77 to make.
bawls
re-learning to ride
posted January 26, 2009 03:58 PM
I've also heard that there's a brass pipe fitting that's supposed to work pretty well.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
jdzx14
posted January 26, 2009 06:16 PM
I used a 1/2 x 20 Lug nut for older 3500 Dodge trucks, works perfect. Its just long enough to fit good in the axle and for the 22mm socket to go on the end of it.
2007 Black ZX-14
kawasakijockey
posted January 26, 2009 07:46 PM
A Craftsman 13/16 spark plug socket works.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
NinjaNick
'08 ZX14 (Blue)
posted January 26, 2009 08:00 PM
I love my universal tool for many bikes:
http://www.motionpro.com/motorcycle/tools/view/t-6_superlight_hex_axle_tool/
Bawls
re-learning to ride
posted January 26, 2009 08:09 PM
If I had a shit ton of motorcycles maybe... but not for 40 dollars only owning 2 bikes.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
rACeRs
posted January 26, 2009 10:42 PM
But Im sure you will be able to use that tool for the rest of your life. Good find ninjanick.
9.1 @ 149 w/ 1.57 60' SWB
FIFTH
The Magnificent Bastard
posted January 27, 2009 02:11 PM
+1
NinjaNick
'08 ZX14 (Blue)
posted January 27, 2009 05:00 PM
Thanks. Yeah, that was my plan. I've used it on 2 bikes so far and I will be using it on many other bikes I purchase throughout my decades here on earth. I like to help buddies out with it too. I just wanted to share what I have and use.
Compton
posted January 27, 2009 06:06 PM
just becareful using it. i've had a few of them snap clean off before. then the fun really starts.
b.w.
3000psi and falling
posted January 27, 2009 07:26 PM
What are the torque specs for front wheel install? Caliper bolts, axle, axle pinch bolts....
NinjaNick
'08 ZX14 (Blue)
posted January 28, 2009 06:50 AM
Front Axle = 94 ft pounds
Front axle clamp bolts (bottom of forks) = 15 ft pounds
Caliper bolts = Just tighten until they stop then give a good tight turn, but not stupid tight.
I have a service manual.
3000psi and falling
posted January 28, 2009 08:00 AM
Great Thanks!
0.54603505134583 seconds processing time
