BIKELAND > FORUMS > ZX-14.com > Thread: 2008 injectors to 2006 bike NEW TOPIC NEW POLL POST REPLY
davisag
posted January 16, 2009 03:26 PM
hi
the general concenus is that the injertors fitted to the 2008 model are better, so i have ordered a set for my 2006 tuned bike to compare and see if i can spot any difference and then fit them and set up again on dyno .
art
starchild
posted January 16, 2009 03:34 PM
injectors
let us know your findings it would be a good upgrade
jay
Ozonkiller
posted January 18, 2009 08:15 PM
I'll be watching
davisag
posted January 20, 2009 09:35 AM
hi
just got and fitted the new injectors today, as well as being a different colour the old injectors have 10 spray holes per nozzle and the new have 12
so will have to see if any improvent when the weather picks up and i can get out and dyno later
art
Ozonkiller
posted January 20, 2009 04:19 PM
It was 80 today, here in Phoenix. Let me know if I can be of any help
Bently
2012 14r In Blue and no Mods!
posted January 20, 2009 04:27 PM
How much where they just incase you see a difference!
masszx14
A mind beside itself!
posted January 20, 2009 07:36 PM
Evilbay has a couple of gen1 injectors, but no 08-09.
+1 on the $$$ question.
universal@mind
madkawboy
posted January 20, 2009 08:16 PM
I found them on www.mrcycles.com for about $50 each
2007 ZX-14
Stock Wheel Base, footshifting, pump gas
5.94 @ 128 mph
1.50 60ft
posted January 21, 2009 01:10 AM
supposed to have a wider spray pattern. should be more efficient. you may get better mpg?
davisag
posted January 21, 2009 01:50 AM
hi
over here in the uk they cost £45 each
art
Swiftkart
posted January 23, 2009 09:51 AM
2008/2009 injectors are $44.95 at www.babbittsonline.com, I got mine early 2008 and never installed them because a friend installed his and they were way richer, you need to have the bike retuned for sure, I haven't gotten around to finishing the project.
MJ
posted January 23, 2009 04:17 PM
Interesting...the 08-09's seem to lose a few ponies from richer mapping. The 08-09 injectors are supposed to be improved for better performance....but yet they run richer and worse on the 06-07 just like they seem to do on the 08-09's. I'm wondering if they were really designed for a performance improvement at all? Or if they're actually part of the new emmissions requirements, and kawi just chose to advertise them as "performance improving"? Things that make you go hmmmm..............
Maybe the 08-09 guys would see an improvement putting 06-07 injectors on their bikes?
davisag
posted February 01, 2009 07:08 AM
hi
bike was out for first run today since i fitted the 08 injectors, and they do flow more fuel for sure, so a remap is definitly in order to see if any power difference
art
suix
posted February 09, 2009 08:15 PM
Any update on the remap?
pissear
Professional Cockis Slap Peer
posted February 09, 2009 09:17 PM
MJ quote: "Maybe the 08-09 guys would see an improvement putting 06-07 injectors on their bikes?" Nope. Been there, done that. '08 is the way to go. '06 injector is going to jet same fuel trim as the '08 ECU map. Seat of the pants wise, nice smooth improvement to be had. It just feels slightly cleaner is all. I'd say the angle has more to do with the smoothing than the spray. Then again, both the different spray pattern and angle helped a tad. Not much, but I would not swap back to the '06 throttle body.
Does the spray improve? Say my home made 4-into-1 loads up as in it sure gurgles richer sounding in the pipe than the '06 t-body did. Interesting you mention richer/ better gas mileage, KZScott.
0.25602889060974 seconds processing time
