BIKELAND > FORUMS > ZX-14.com > Thread: Air compressor install NEW TOPIC NEW POLL POST REPLY
1badvespa1400cc
power junkie
posted January 06, 2009 12:21 PM
Any pics on air compressors installed for air shifter application?
Just another foeteen!!!!!
06redzx14
posted January 06, 2009 12:32 PM
I don't have pics right now, but I used the space right behind the tank between the 2 rails that run across(left to right) of the subframe
posted January 06, 2009 12:41 PM
you need a place for a low pressure tank too right? thought about using the arm for that? (save space)
1badvespa1400cc
power junkie
posted January 06, 2009 12:42 PM
Did you leave it in the plastic container or take it out,I have my mps box in the back and it is kinda tight back there.
1badvespa1400cc
power junkie
posted January 06, 2009 12:43 PM
I have that part taken care of just need a spot for the air compressor.
06redzx14
posted January 06, 2009 01:16 PM
my kill box is in the back near the ecu. the space behind the tank I used for the compressor. 9 oz co2 bottle in the key side of the tail section for my tank
jarhead
posted January 06, 2009 01:22 PM
I did an install on a 14 a few years back and pulled the tool kit out, compressor sat in there great. I powdercoated the air tank black and mounted it on the belly wing. It turned out good and I still see the bike from time to time and he has not had any problems to date.
1badvespa1400cc
power junkie
posted January 06, 2009 03:38 PM
I also have a tiger racing undertail if that makes any differance,I think thats why I am having some issues with room.
kawasakijockey
posted January 06, 2009 05:17 PM
If you dont have anything in that hollow spot in the battery tray put it in there.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
Brent Davis
posted January 06, 2009 07:35 PM
Black '06 ZX-14
Bawls
re-learning to ride
posted January 06, 2009 07:44 PM
holy jeezus that's a nice bike lol. I take it that your passenger seat is no longer useable?
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Brent Davis
posted January 07, 2009 02:54 AM
Thanks.
No the passenger seat is no longer useable but just buy another stock seat, bolt it on and go. When you wanna go racing, swap the seats back out.
Black '06 ZX-14
1badvespa1400cc
power junkie
posted January 07, 2009 06:03 AM
How did you mount it to the undertail?
06redzx14
posted January 07, 2009 06:12 AM
I used tie wraps 1 to hold the pump and 1 to hold the part the tubes come out
1badvespa1400cc
power junkie
posted January 07, 2009 06:25 AM
The tie wraps dont get hot when the pump is running?
06redzx14
posted January 07, 2009 07:09 AM
no the pump will never run that long. I've had mine on for 6-7 months without issue
kawasakijockey
posted January 07, 2009 07:26 AM
You used some expensive hose and fittings for air line, huh?
2007 ZX-14
1.38 60ft
9.03 @ 149mph
Brent Davis
posted January 07, 2009 08:46 AM
[quote
Yeah, I just didn't want an issue later on. My pump is mounted using the two stock holes on it and it is bolted to the bike but I can assure you that if you did zip-tie it, the pump doesn't get hot enuff to burn your hand so you'll be fine.
Black '06 ZX-14
1badvespa1400cc
power junkie
posted January 07, 2009 09:32 AM
Where did you purchase the compressor?
Brent Davis
posted January 07, 2009 11:06 AM
It is just a Walmart mini tire air pump. Take the pump out and mount it. I paid $10 for it and it works great. No filling a bottle or hanging off the side of my bike.
Black '06 ZX-14
06redzx14
posted January 07, 2009 11:47 AM
make sure it is one rated for 250 psi
1badvespa1400cc
power junkie
posted January 07, 2009 12:21 PM
I thought you only needed 120 psi to run the air shifter?
06redzx14
posted January 07, 2009 01:06 PM
I run mine at 140 psi because of the heavy duty clutch springs.
1badvespa1400cc
power junkie
posted January 07, 2009 01:30 PM
Where are you getting power from to run the compressor,I was going to run a inline 15 amp fuse and get power from the taillight.
posted January 07, 2009 05:02 PM
When running power to a motor you need to get power straight from the battery. The power wire running to the tail light is too small
0.45045709609985 seconds processing time
