BIKELAND > FORUMS > ZX-14.com > Thread: T-Rex Racing Motorcycle Stands? NEW TOPIC NEW POLL POST REPLY
Luuk
posted December 28, 2008 04:54 PM        Edited By: Luuk on 29 Dec 2008 00:54
I have a T-Rex Motorcycle Stand and I have this spool to go with it (that they recommended)
http://t-rex-racing.com/catalog.php?item=7&catid=20&ret=catalog.php%3Fcategory%3D20
I was given it as a gift for Christmas (woot!) and the spool doesn't fit? When you try to screw it in the swingarm is slanted and the spool doesn't screw all the way in...or even in hardly at all.
Anyone else had this issue?
*Edit- forgot to mention I have an '08 SE
Ninja14
posted December 28, 2008 05:18 PM        Edited By: Ninja14 on 29 Dec 2008 01:18
Sure it is the right size?
I picked up some cheap spools when getting my tires mounted....never had any problems.
Maybe a picture will help us solve it.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
posted December 28, 2008 05:20 PM
i have t- rex stands but i bought my spools separately. i had the same issue with the spools i found but used a 10mm(i believe) bolt to space the spools out. it worked perfect.
Luuk
posted December 28, 2008 05:33 PM
Hmm...not sure it's the right size I guess - just was hoping they shipped the wrong part and all of you guys' stands worked fine
I'll have to contact them on Monday.
Bigdtd, yours had the same problem? You just had to get a longer bolt?
WARBIRD
posted December 28, 2008 05:39 PM
They are probably the wrong size. By some from Pitbull......they have the spacers with them.
pit-bull.com
I'd Rather Be Roadracing.
posted December 28, 2008 05:46 PM        Edited By: bigdtd on 29 Dec 2008 01:47
the bolts i got were long enough to use a nut for a spacer
jdzx14
posted December 28, 2008 06:59 PM
Like said, proly the wrong thread or could need to be cleaned with a tap. I also have the t-rex stand and i love it!!! Good luck.
2007 Black ZX-14
pazx14rider
posted December 29, 2008 02:14 PM
IF you know someone with a metal lathe you can take a bit off the inside thats what i did for my buddys 10R he had the same problem
pazx14rider
posted December 29, 2008 02:15 PM
And to add to that i should be getting mine this week in the mail i cant wait, looks like a nice stand
NeverKnow
posted December 30, 2008 08:46 PM
Purchased the front and rear T-Rex stands and 10mm spools; all worked fine
kawboy81
Busa Eater
posted December 30, 2008 09:49 PM
ive had my t-rex stands for about 2 years now.....no problems at all. i bought spools seperate though. sounds like the threads on ur bolts may b wrong pitch or size.....go pick up some 10mm and see if that helps.
07 LE bolt on bike
0.29410886764526 seconds processing time
