BIKELAND > FORUMS > ZX-14.com > Thread: 60ft times. NEW TOPIC NEW POLL POST REPLY
kimski2001
posted November 24, 2008 07:10 AM
60ft times.
Is there some secret to getting into the low 1.40's high 1.30's?My bike is about 4.5 inches over and the best so far is a 1.48!been 2 it for a year and a half.I look @ some of you guys 60ft's and think HOW THE F--K?Any help is appreciated!
1st14injax
ninjaboy311
posted November 24, 2008 07:26 AM
Good clutch hand!!
I know my bike is 69", but this past Friday, a cold front swept through, and the density altitude was negative 1500 ft. Using 87 Chevron pump gas, I was cutting 1.33 60 foots every pass and went 8.83, my quickest ever on pump gas. I know thats off the subject, but just to show that good air helps your 60 foot times too.
Your wheelbase is kinda short. Its going to be hard to get into the 1.3's. How much do you weigh? Another thing is that you need the right suspension set-up too.
kimski2001
posted November 24, 2008 07:51 AM
230 fully dressed using a stock shock,thinking of getting it revalved though.
1st14injax
00Busa
Trying to go FASTER !
posted November 24, 2008 08:31 AM
I can get mid 1.3s at 62.5" but I only weigh 175 lbs. I leave at 3000 rpms and get the clutch out quick as I can. There's a fine line between wheelying and tire spin but only seat time will take care of that.
'00 Busa / '06 14 /
IT AINT BRAGGING, IF YOU CAN BACK IT UP !
ninja12
posted November 26, 2008 05:07 AM
any weight added to get these good 60's?
madboost
posted November 26, 2008 05:19 AM
1.48 is actually pretty decent at your weight.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
00Busa
posted November 26, 2008 06:00 AM
No weight added but 4" added to the wheelbase and lowering helps dramatically.
'00 Busa / '06 14 /
posted November 26, 2008 07:04 AM
what shock are you running Pat?
kimski2001
posted November 26, 2008 08:12 AM
thanks for the replies guys!how low is your bike?
1st14injax
1badvespa1400cc
power junkie
posted November 26, 2008 08:30 AM
Kim i've seen you run and it look's good to me atleast when I see the bike's that are behind,mostly gsxr 1000's(lol).
Just another foeteen!!!!!
Silver08
posted November 26, 2008 10:16 AM
ninjaboy, how much time did it take to set up your Litz?
08 ZX14
gilberjj
Friend of Fast
posted November 26, 2008 11:10 AM
hmmm..... my best is 1.74........ looks like I have some work to do
madboost
posted November 26, 2008 11:12 AM
from what i understand he got it already set up and just put it on his bike without adjustments, cant wait to sent mine out.
9.44@144 w 1.5060ft
ninjaboy311
posted November 26, 2008 12:14 PM        Edited By: ninjaboy311 on 26 Nov 2008 20:16
That's right guys, sent a stock shock to Adam's Performance (Litz). In the box, include a note with your wheelbase, rider weight (suited up), and your bikes HP.
I had them re-valve, re-spring, and shorten it by 1".
They set it up according to the information you provide. It is your decision if you want to re-spring it or not.
I had to make one very small adjustment when it came in. It was a little too tight, so according to Coby, I had to loosen 1 round on the compression screw and loosen 1 round on the rebound screw. That was it, and I haven't touched it since. Now it is very rigid feeling (when riding slowly), but it is designed for drag racing. Check out these before and after pictures of how high I used to have to keep my subframe so that the tail wouldn't bottom out when I launch....compared to now how low I can drop the subframe because the bikes doesn't squat nearly as much, and it works so much better now....
And here's a launch with the new shock, see how it barely squats....
Silver08
posted November 26, 2008 04:27 PM
ninjaboy
I have a Litz shock and spring. How did you determine that the shock was too tight? Mine is so stiff anyway from using the Adams straight link, I dont know what is too tight. I spun at the track last week, but I'm not sure if it was due to shock setup, too much tire pressure, track temp or track prep.
also, does it affect the shock if I lower the rear more on my bike?
08 ZX14
pazx14rider
posted November 26, 2008 06:01 PM
what is stock wheel base on the 14 just so i can compare?
Silver08
posted November 26, 2008 06:08 PM
57.5
08 ZX14
1badvespa1400cc
power junkie
posted November 26, 2008 07:17 PM
Ninja boy that bike is looking sweet!!!
ninjaboy311
posted November 26, 2008 11:36 PM        Edited By: ninjaboy311 on 27 Nov 2008 07:39
ninjaboy
Well, I installed it, and theres a few small bumps on the track, that normally I wouldn't feel, but with the shock so tight, the bike was coming off of the ground everytime it hit a bump. So I called Coby, and he told me to loosen it just a bit. And then it worked perfectly.
No it doesn't affect the shock if you lower the rear more.
ninjaboy311
posted November 26, 2008 11:38 PM
Thanks!!
posted November 27, 2008 12:51 AM
Hey Pat, Im sending my shock to Coby to get revalved sometime this winter. how much would you say having it shortened at the same time helped? is it basically for ground clearance? much added to the cost? I was asking him about it last week and he didnt mention getting it shortened, and said a respring usually wasnt needed after revalving. comparing a 12R to a 14, but should be pretty much the same idea imo
thx
pazx14rider
posted November 27, 2008 05:36 AM
thanx silver
ninjaboy311
posted November 27, 2008 07:32 AM
thx
I shortened it to work in conjunction with the Adam's straightlink, which is basically for ground clearance. Not sure about the price, I don't think it was any more.
smokehouse4444
XX to ZX
posted November 27, 2008 08:18 AM
These 60ft times are so interesting. A racing buddy jumped on my stock wheelbase bike and this is what it looked like between us:
mine his
reaction .0298 .4374
60ft 1.74 1.77
330ft 4.62 4.44
1/8 6.85 6.56
1/8mph 110.01 116.58
1/4 10.39 9.94
1/4mph 137.20 144.93
Good luck Kimski, hope you get that low 1.4.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
posted November 27, 2008 09:18 AM
thx Pat
0.39023017883301 seconds processing time
