BIKELAND > FORUMS > ZX-14.com > Thread: How lean is too lean? NEW TOPIC NEW POLL POST REPLY
kawabonzai
Leader of the Back.
posted November 12, 2008 09:43 PM
Hi there gang,
I didn't wanna derail the other thread, but comments about the 09 being more lean than my 08 had me concerned. Take a look at this dyno sheet, 08 versus 09.
Is the 09 in the danger for being too lean? Myself I like the 08 curve better, a bit on the safer side around 13.1.
Should I go in and have the fat bottom end mapped leaner and juicen up the leaner top end?
2009 ZX-14 Candy Lime Green
smokinzx14
posted November 12, 2008 09:59 PM
You are in no danger at 13.8 .... New cars run 14.2 or leaner .... Will 13.8 be the best for the track ? Most likely not ...... With ram air blasting down the track 12.9 to 13.1 works better ..
posted November 12, 2008 10:44 PM        Edited By: KZScott on 13 Nov 2008 06:45
I like 12.6-12.8:1 based on a few very smart guys oppinions. 12.8 for best power, 12.6 for best acceleration
cars dont have the compression bikes do most of the time
BobC
posted November 13, 2008 06:58 AM
I always thought the ideal theoretical stoichiometric air/fuel ratio for pump gas was 14.7 : 1 although most bike applications seem to stay on the right side of 14. (That's below 14:1)
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
posted November 13, 2008 08:18 AM
it is but nothing is that efficient, and a little extra to keep things cool is allways a good(safe) idea
kllrvet
posted November 13, 2008 10:21 AM
14.7 is only good for cruising for maximum fuel economy, and minimal emissions, but potentially danherous a WOT (this is in reference to NA only). 13.8 ish at WOT while not at all optimum, isn't dangerous either.
ZX14 cam chain tensioner making noise? I have the set it and forget it fix. PM me if I can help.
0.25241708755493 seconds processing time
