BIKELAND > FORUMS > ZX-14.com > Thread: How to lift front end without a stand? NEW TOPIC NEW POLL POST REPLY
jdzx14
posted November 11, 2008 09:35 AM
I am wanting to have my wheels powdercoated over the winter and i have a rear stand and am leary about buying a front because its lowered and might not work, so is there any other alternative? Thanks.
2007 Black ZX-14
ninjaboy311
posted November 11, 2008 09:42 AM
If you can access an overhead beam, or an overhead winch, you can lift it like that. Or I've seen jacking it up (oil pan) and installing jack stands under the forks.
NINJA12
posted November 11, 2008 10:15 AM
there are front stands that use the bottom of the forks.
Not like the pit bull stands.
look at this picture.
http://cgi.ebay.com/ebaymotors/SPORT-BIKE-MOTORCYCLE-STAND-FRONT-REAR-SWINGARM-SET_W0QQcmdZViewItemQQ_trkparmsZ72Q3a543Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZitem190265845377QQitemZ190265845377QQptZApparelQ5fMerchandise
posted November 11, 2008 10:18 AM
I was thinking this was a wheelie post
bawls
re-learning to ride
posted November 11, 2008 11:45 AM        Edited By: bawls on 11 Nov 2008 19:46
Try that
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
DogoZX
posted November 11, 2008 12:28 PM
This stand works for me:
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=282618&store=Main&catId=&productId=p282618&leafCatId=&mmyId=
But cut a 2x4 to brace it the width of the forks. After the wheel is removed, the forks will want to squeeze closer together.
jdzx14
posted November 11, 2008 03:17 PM
It says the forks must have pinholes in the bottom of them to use this stand.
2007 Black ZX-14
02zx12rbob
posted November 11, 2008 03:24 PM
Engine hoist works.
DogoZX
posted November 11, 2008 03:35 PM
Your's don't?
Mine do.
The pins on that front stand are a little long though. I shaved off about a quarter inch.
posted November 11, 2008 04:05 PM
there are two types of front stands, one the pin goes into the neck, the other rests the forks on top.
the one with the pin in the neck may be a better investment, as it allows the entire forks to be taken of. this is required for clip on replaces, fork maintenance, etc.
c'mon man break down and get a front stand!
VORTEX stand on the left bike about a hundred bucks, cheap stand on the right bike about 60 bux. You'll use 'em forever!
Bluebyyou
Gettin My Curve On
posted November 11, 2008 04:44 PM
Not real sure why you don't want to use a front stand. I use front and rear stands together for tire changes etc., no problem it's stable. I did also made a makeshift hoist in the garage ceiling joist with a couple of rachet tiedowns that works well too.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
posted November 11, 2008 04:46 PM
+1
gilberjj
Friend of Fast
posted November 11, 2008 06:26 PM
hmmmm. I really don't want to spend any money on a stand I'll only use 2-3 times a year. I'm going to try this hoist thing.....
NinjaNick
'08 ZX14 (Blue)
posted November 11, 2008 06:40 PM        Edited By: NinjaNick on 12 Nov 2008 02:41
To each their own. I will say that I have had my stands for over 4 years now and I've had 3 bikes on them too. I rest my bike on my front and rear stands each time I wash it, each time I oil change, each time I change my rear tire, each time I change my brake pads, each time I change my coolant, each time I change my brake fluid, and after each long ride if I'm not going to ride it for more than 2 days. Probably hoisted my bikes up on them well over 200 times.
posted November 11, 2008 07:56 PM
hoisting it is simple too, but as many have said you'd use stands all the time. honestly, it makes messing with the bike so much easier you'll wonder how you ever did without them.
Newf14
2007 ZX1400
posted November 12, 2008 05:03 AM
Trust me you will use the stands, I use mine for everything. I have her stored for the winter now and she is up on her two stands. I have a universal rear stand which goes under the swingarm on platforms, and the front one goes in the hole in the tripple tree.
Newf14
jdzx14
posted November 12, 2008 05:19 AM
So these stands you guys recomend will work with a 14 that is lowered an 1.25" in the front? I dont need a rear, i already have that, i need a front. Because i know that the local bike shop hates to put front tires on my bike because of how low it is.
2007 Black ZX-14
NinjaNick
'08 ZX14 (Blue)
posted November 12, 2008 06:14 AM
I don't see why it wouldn't work, because the forks are still the same length from the ground unless you got a smaller tire. Lowered or not, the bottom of the forks are still the same height from the ground.
posted November 12, 2008 07:23 AM
if you are worried about room between the front fender and neck, use a front stand that lifts by the forks themselves. those stands are priceless for wheel maintenance too.
posted November 12, 2008 08:10 AM
get one that picks up by the bottom of the forks and be done with it. lowering the bike has nothing to do with this type of stand. mines lowered and i use for everything as the guys have stated above!
kaw now
posted November 12, 2008 10:11 AM
Its quite simple take one center stand - you have one don't you - and one small jack and here you go.
posted November 12, 2008 10:40 AM
i bought a set of el cheapo front and rear stands for $100. i had to extend the rear stand to work with stretched wb, but i use them all the time. love them, would probly love a nice set even more but these do the job.
flite leader
posted November 12, 2008 11:39 AM
if you are at home in your garage
use 2 Ancra tie down straps from the ceiling timbers
use soft straps at the handle bars or the top of the triple tree
swing it...... pull the wheel
the biggest benefit is it cant fall over
bend your mind.....
or break your ass...!!
bawls
re-learning to ride
posted November 12, 2008 02:37 PM
I used ratchet straps from the cross beams in my garage to lift my bike off of the rear stand, and then used the stand itsself for leverage on the swingarm while getting it into position lol. Gangsta
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
jdzx14
posted November 12, 2008 03:22 PM
I will buy a front stand, i love the rear stand and it has easily paid for itself, i was thinking about the kind of stand that uses the pin and hole above the fender.
2007 Black ZX-14
0.25988912582397 seconds processing time
