BIKELAND > FORUMS > ZX-14.com > Thread: Quickest pass to date.... NEW TOPIC NEW POLL POST REPLY
ninjaboy311
posted November 09, 2008 07:18 PM
Finished off a can of MR9 this past Friday night, and went my quickest pass ever, 8.826 @ 151.46 MPH. Ended up winning the all-run gambler's race vs. a Super Pro (electronics) car, and also was runner up in the motorcycle trophy race.
Here's the time slip, but may be hard to see...
Then on Saturday, went back to 87 pump gas. After I lost out, I put a friend of mine on my bike to make a hit. He weighs 165 unsuited. He blasted an 8.801 @ 154.99, with a 1.340 60', and 127.22 MPH in the 1/8th. Here's the time slip....
And then I let another friend make a hit, that weighs about the same (165-170) and owns a ZX-14 as well. He didn't launch quite as hard, but what amazed me was the MPH the bike cranked out....128.59 1/8th, and 155.08 in the 1/4, on 87 pump gas. Here's the time slip....
The bike is 2 years old, and has about 800 or more passes. Still never adjusted the valves or anything else in the engine, only changed clutches and spark plugs so far.
smokinzx14
posted November 09, 2008 07:59 PM
Very cool ...Nice win !!!
johnsonzx14
posted November 09, 2008 08:03 PM
awesome, damn I need to take mine out and freakin race it...
kawboy81
Busa Eater
posted November 09, 2008 09:15 PM
damn good times! nice!
07 LE bolt on bike
billeason
posted November 10, 2008 05:18 AM
what rpm's are you leaving with that long arm. It has to be hooking to run 137 60'. That's some good running there 311....
bill eason
madboost
posted November 10, 2008 06:11 AM
damn awsome times how often do you change plugs? I got about 2800 miles on mine just wondering.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
ninjaboy311
posted November 10, 2008 07:17 AM
Launching at 4000 Bill. That 180-55 Michelin is getting it done.
ninjaboy311
posted November 10, 2008 07:19 AM        Edited By: ninjaboy311 on 10 Nov 2008 15:28
I don't ride on the street. I have 2800 miles too, but 2300 of them are going down the track and in the pits.
I only change them about once a year, which I know I should be doing it more often with the type of abuse I put the bike through.
FlatoutBu
posted November 10, 2008 08:14 AM
Ninjaboy what wheel base is that bike sitting at? I have been chasing my 8's all this year and never quite made it. The pilot power took a crap on me and i never could get it to hook, but not because it was wore out but it just got old and started to dry up. I had it for over a year and a half and loved it. I had horrible 60's 1.61-1.67 spinning, but still pulled 151-152 out the back door at the end of this year. This was with u4 and some cold weather....hopefully come spring with a fresh tire and clutch i can get my low 1.4'-1.3's back and run those numbers...good job, keep giving that bike hell.
06 Blue 14
9.008 at 153mph @ 195 suited
ninjaboy311
posted November 10, 2008 08:29 AM
Thanks.
Bike is at 69", 16-44 gearing. Is that Michelin you had the Power Race 'soft'?
FlatoutBu
posted November 10, 2008 08:50 AM
yup...had it over a year and a half and about 200-250 pass's. It started dry cracking at the end of the year...you know where you rub your hand over it after a burnout and instead of being hot and sticky it's hot and feels like sand paper. I also have the same gearing but i'm at 651/2. I ordered my arm a little long and can't go any shorter.
I could run 22-25 psi in that tire when it was new with no problems.
06 Blue 14
JohnnyRocketZX14
posted November 10, 2008 08:53 AM
Ninjaboy what front tire are you running?? Size? is there less resistance to be had up front with a particular tire??
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
ninjaboy311
posted November 10, 2008 09:28 AM
I have a Michelin Pilot 120-60 on front. Its a pretty hard tire. You don't want a soft tire on front, it will slow you down.
posted November 10, 2008 09:45 AM
I'm headed to the track tomorrow and I have a wheel with a power race soft 180, and my Shinko 190 U-soft. The big variable tomorrow morning is that the temp will be about 40 degrees or less at the track!
madboost
posted November 10, 2008 09:52 AM
Is that on a stock shock? if so what is your preload sag set at?
9.44@144 w 1.5060ft
ninjaboy311
Cool, keep us posted on the results and track conditions.
posted November 10, 2008 01:19 PM        Edited By: Shane661 on 10 Nov 2008 21:20
If I can get a few 9.3's on the Shinko, then I will give the Michelin a try. I don't have a bigger sprocket, so I will be losing a little gear with it.
ninjaboy311
posted November 10, 2008 02:17 PM
Maybe....but you'll be surprised. My buddy put a Michelin 180-55 on his ZX-12 this Saturday (had a 190-50 Shinko U-soft), and first pass out had a 1.37 60' and went 8.97 on MR9. he hadn't changed any gearing or shock settings, just swapped tires.
ninjaboy311
posted November 10, 2008 02:20 PM
I have a rebuilt stock shock from Litz. It's re-valved and re-sprung according to my weight, swingarm length, and horsepower, and I had them shorten it by 1".
Its set at where they set it in their shop, didn't have to touch anything.
JohnnyRocketZX14
posted November 10, 2008 03:40 PM
ninjaboy311 have you tried litz's XXX fuel?
07 ZX14
ninjaboy311
posted November 10, 2008 03:57 PM
No I haven't. I hear its really high octane. I'd be willing to give it a shot. Theres a guy in New Orleans thats gonna be a dealer. I may get some one day to try it.
JohnnyRocketZX14
posted November 10, 2008 07:22 PM        Edited By: JohnnyRocketZX14 on 11 Nov 2008 03:24
looks like they have a 101 octane i would try, my guess is its similar to MRX01 since its a oxy fuel. They have a interesting article on dyno results
http://www.xxxracingfuel.com/?p=23
P.S am curious what it cost to have the shock done if you don't mind
07 ZX14
ninjaboy311
posted November 10, 2008 07:36 PM
I paid $450 to get the work done to a stock shock.
4Racing
VP Race Fuel Expert
posted November 11, 2008 04:52 PM
Your bike is flying. Did you see this pic of you at HRP 11/2/08?
http://www.gulfimagesphoto.com/ha/20081102/action/0811023976.html
ninjaboy311
posted November 11, 2008 05:10 PM
Yea I saw that, and I'm gonna have to buy that pic!!
0.29723715782166 seconds processing time
