Bink2go
posted November 05, 2008 03:16 PM
Oil filter wrench
Went to change my filter and it's ON there. Tried a cap style and all it wanted to do was slip. Seems it's an odd size. Frams web site says to use a 66/68, it's too big. Anyone have the room or luck using one of the spider style wrenches? Read a few things on here that the factory tightens them way too much.
Thanks,
Chris
street racer
posted November 05, 2008 03:28 PM
I have a "pliers" type oil filter wrench from Auto Zone which I have used on my last 4 bikes. It works great for removing the filter but can wreck a filter if you use it to tighten a new filter.
WindSwordNinja
posted November 05, 2008 03:36 PM
I have an oil filter wrench that is a handle with a rubber strap attached to one end, and the other end you can slip into a groove after wrapping around the filter.
The more you turn it the tighter it gets, and it fits in tight clearances.
I haven't had a problem getting filters off with it.
I guess if your filter is on WAY TOO TIGHT it might break the strap or crush the filter.
Then it's time to bring out the big channel locks!
Make sure you apply a thin film of oil on the gasket when you replace the filter, and don't over tighten it.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
posted November 05, 2008 03:45 PM
Get the Kawasaki filter wrench...Channel locks...pipe wrench...strap...screw driver and hammer...
ratbyk
posted November 05, 2008 04:50 PM
I bought a KD tool #3253 that fits it exactly.
Nixter
posted November 05, 2008 08:25 PM
quote: I have a "pliers" type oil filter wrench from Auto Zone which I have used on my last 4 bikes. It works great for removing the filter but can wreck a filter if you use it to tighten a new filter.
+1 to remove old filter. The new one can be put on tight enough by hand.
2012 ZX14R - Black
Hawkman
posted November 05, 2008 10:06 PM
Get one of deez:
posted November 05, 2008 10:43 PM
maybe she can give you tips
Superman T
posted November 06, 2008 04:49 AM
Autozone has box cap socket wrench that fits perfectly!Just 3/8 ratchet & it' s off!Part #25404 oil filter "F" cap wrench
ghostman
posted November 06, 2008 04:53 AM
BIG-ASS CHANNEL LOCKS!!!
Tighten by hand though.
I'm There Whether You See Me Or Not.
Bink2go
posted November 06, 2008 10:43 AM
Got the pliers type...yeah one of doze Hawkman. Mangled by the time I got it off, but it's off. First filter change...Kawi has some over do it assembly men!! Thank God they didn't torque that frame bolt down like that!!
Thanks all,
Chris
slates
posted November 06, 2008 11:49 AM
Tighten by hand...drain oil thn, hammer a screw driver through the old filter and loosen it, then remove by hand.
GHOSTMAN
posted November 06, 2008 11:54 AM
Ha!!! I said channel locks earlier, but ended up grabbing a nice long flat-head screwdriver this morning!!
Go figure . . . .
Bink2go
posted November 06, 2008 10:39 PM
Space between oil filter and concrete doesn't leave much! If I hadn't found that angled plier wrench it would of been the ole shade tree mechanic screwdriver. One good thing they atleast made it accesible without taking anything off. I always enjoyed my old 84 Blazer. Take a 1 foot socket extension (actually a bunch of them, whatever was laying around in the garage) and cap end thru the inner fender. Lay into into with a breaker bar...no problem. LOL
Bluebyyou
Gettin My Curve On
posted November 07, 2008 02:22 AM
I maintain two street bikes and two ATV's and have many different filter tools but this one seems to work best:
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
Hawkman
posted November 08, 2008 12:40 AM
That one wouldn't work on my 14 now that I've got a Purolator 14610 filter on it. I wouldn't be able to get that wrench on. Filter is too close to the header.
