BIKELAND > FORUMS > ZX-14.com > Thread: How do you remove flys? NEW TOPIC NEW POLL POST REPLY
WindSwordNinja
posted October 30, 2008 11:59 AM
Hey everyone, I'm new to this forum, and just getting back into motorcycles after a long hiatus.
I've read here that I should remove the flys off of my 2008 however I'm not sure how to get to them. I imagine they are under the tank but I'm not sure how much of the plastic I have to remove just to get the tank out of the way. Does anyone know where I can go to get a basic step by step proceedure? Thanks.
2014 ZX14 Black and Green
2008 ZX14 Black and Red SE
1986 ZX1000R Black
"Faster, faster! Faster would be better!" (Serenity)
KawaBonzai
Leader of the Back.
posted October 30, 2008 12:07 PM
First off, welcome to the site.
Secondly, you're gonna get flamed for not using the search, even though it suck.s.
third ... Get a BRAND NEW Klein #2 7-inch screwdriver from lowes.
Prop the tank up with a 2x4.
Remove the cover plates above the airbox.
SLOWLY ... (I mean it) unscrew the two screws per plate. Did I mention SLOWLY?
Rince and repeat 3 more times.
Replace the covers.
Secure the tank.
For your reading pleasure and to save you from using the search function ...
http://www.bikeland.org/board/viewthread.php?TID=41663&FID=27
http://www.bikeland.org/board/viewthread.php?FID=27&TID=24193
With Pictures >>>> http://www.zxforums.com/forums/zx-14-forum/7500-flies-out-picture-guide.html <<<<
2009 ZX-14 Candy Lime Green
KawaBonzai
Leader of the Back.
posted October 30, 2008 12:09 PM
And by slowly I want you to pretend that your torque'n on a socket and you know that if you slip you'll get BLOODY knuckles.
With the fear of BLOODY knuckles in mind, remove the screws ... SLOWLY.
KawaBonzai
Leader of the Back.
posted October 30, 2008 12:10 PM        Edited By: KawaBonzai on 30 Oct 2008 20:13
SLOWLY..........SLOWLY..........SLOWLY..........SLOWLY
WindSwordNinja
posted October 30, 2008 12:26 PM
Thanks KawaBonzai for the quick reply. That is just what I needed! It looks like I can remove the tank without having to remove the side panels (just the air intake covers).
BTW I did try a search first however it didn't show anything useful. I could have just not phrased it correctly. I hope I don't get flamed too bad!
How do you like your Buell Pegs, and what is a Heli Riser?
1986 ZX1000R Black
KawaBonzai
Leader of the Back.
posted October 30, 2008 12:36 PM
The Heli risers are 1.25 inch spacers that go between the triple clamps and the clip-on's.
Combined with the Buell pegs I get a bit more upright without sacrificing anything really. My hips and bone spurs thank me every time.
check out the install FAQ ... http://www.helibars.com/instructions/kawasaki/HC2614.pdf
gilberjj
Friend of Fast
posted October 30, 2008 12:37 PM
I would heat the fly bolts if possible first. I didn't have a soldering iron or other means of heating the actual bolts, so I used a lighter on the screw driver head for about 30 seconds, then put that on the fly bolts. This melts the loc-tite on the bolts, and the bolts came out as if they weren't even torqued. I HIGHLY recommend this. TAKE YOUR TIME. If you do it right, you won't have to take the throttle bodies out to get out a stripped bolt.
MJ
posted October 30, 2008 12:51 PM
No need to pull them on an 08 and up
Scalded Dawg
posted October 30, 2008 12:57 PM        Edited By: Scalded Dawg on 30 Oct 2008 21:01
+1 Soldering Iron...a must...the heat releases the lock tite stuff....
Harbour Friegth soldering iron is like 3 bucks...well worth the headache avoidance...
And plumbers putty around the outside of the fly (round part)...keeps it in place in case you drop a screw...after all the screws are out...pull the flies. Drop a screw down the hole and you will want to slit you own throat.
DogoZX
posted October 30, 2008 01:05 PM
I let the bike run untill everything was nice and warm. Screws came right out.
It also helped to tighten the screws, just until I heard the loctite break free, before loosening them.
dcjens
Wet side of Washington
posted October 30, 2008 06:44 PM
baaaaah mine came out easy, cold motor. I set the klein screwdriver on a speaker magnet to charge it a little.
Black 06
Scalded Dawg
posted October 31, 2008 01:37 AM
I knew a guy the rode hookers bareback too...His dick fell of one day...
Take a chance...Is only like 2-3 hours of extra labor if strip one of them screws. I am sure one of these guys will come over and help you...Me, I will be out riding...
Bluebyyou
Gettin My Curve On
posted October 31, 2008 03:41 AM        Edited By: Bluebyyou on 31 Oct 2008 11:42
I'm a member and a fan of the flys out club. Alls it cost me was some labor and a new #2 phillips screwdriver. This has to be the simplest and cheapest mod with the most gain I've ever done. No regrets here,it totally transforms the bike from a smothered beast to a delightful giantkilla.
2007 Bad to the Bone ZX-14 flies out, full Muzzy exhaust system, PC III, BMC race
AZ ZX14
posted October 31, 2008 04:21 AM
Go flies out. It will really help your 08 run better in the low end. Consider also getting the PCIII so you can fine tune it.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
NYC ZX-14
Manager Star Toyota Bayside,NY
posted November 02, 2008 08:48 PM
Hold on a minute.... You mean I CAN pull the flies on my '07 WITHOUT a PCIII??? Won't that F-up the motor?
Currently?
2007 Kawasaki ZX-14, 1999 Kawasaki VN 750, 1976 Suzuki RE-5 Rotary
http://www.goldiesplating.com
  Ignore this member    Click here to visit NYC ZX-14's homepage.
posted November 02, 2008 08:58 PM
Replace the covers.
Secure the tank.
Burnrubber1
Some chrome
posted November 02, 2008 09:47 PM
Yeah I'm with ya on this one! Been waitin' for a chance to take them out!
AZ ZX14
posted November 03, 2008 05:34 AM
Sorry guys I stand corrected.
You should use the PCIII whenever removing flies. This will correct the lean spot that will exist in the 3 to 4K range.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
bawls
re-learning to ride
posted November 03, 2008 02:04 PM
I've got a buddy on base that has 6k miles on his 07 without the flies and no pc3. As long as you remember that there is one little spike from 3500 to 3700ish and keep from staying in that range, you're golden. The bike gets it's best mileage at 4k anyway so there's no need to lug the engine.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
WindSwordNinja
posted November 03, 2008 02:32 PM
I do have a PCIII/USB, and I ordered the LCD screen for it over the weekend.
I plan on removing the secondary butterfly valves on Friday, and spend Saturday tuning it in.
Soon I'll be a member of the NO FLIES club.
I'll let you know how it turns out.
Thanks for all the input, and I'm sure I'll have some questions about dialing it in.
1986 ZX1000R Black
NYC ZX-14
posted November 03, 2008 04:25 PM        Edited By: NYC ZX-14 on 4 Nov 2008 00:36
"To pull or not to pull.... that is the question" lol.... Especially without a PCIII like me. :o(
We hear "Do It" and "Don't do it" I wonder if the dealer would answer honestly (if they even KNOW)
Currently?
Burnrubber1
Some chrome
posted November 03, 2008 05:03 PM
I'm sure a dealer would probably come up with something along the lines of them being in there for a reason!
bawls
re-learning to ride
posted November 03, 2008 06:10 PM
I've ridden his bike and the only way that you can tell that there is a lean spike is by putting it on a dyno. Plugs look perfect on it. I personally think that if no one posted anything about a lean spike, everyone would pull their flies and not worry about it. I can't tell you the last time that I was at 3500 to 3700 rpm for more than a second or two. But then again, I've only put about 7 thousand miles on my bike since july lol.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
countersteer
Didn't read the owners manual
posted November 03, 2008 06:18 PM
amazing that some of you cant afford a $300 power commander. and you can even get the map for free.
Scott
Long Island, New York
2006 ZX-14, 2003 ZX-12R
NYC ZX-14
posted November 03, 2008 09:30 PM
300 bucks isn't much, especially if ones racing their bike then I would say it is downright CHEAP! But for those of us who like (and are able to) tinker, and are quite happy with the stock power output as is from the factory anyway, we can't justify blowing $300 bucks on a totally non-essential (for us non-racers) upgrade.
However, if pulling the flies without having to spend any money and getting a free boost is do-able, then that's what we're after. If not, then I'd just as soon leave it flies-in. The 14 is plenty powerful for me.
That being said, I just finished pulling the flies on mine (I was bored). Whooo-hoooo!!!! I absolutely LOVE the new found bottom end!!!! THIS is how the bike should come from the factory!!!
Currently?
All times are America/Va [ This thread is 4 pages long: 1  2  3  4     Next» ] < Previous Thread     Next Thread >
0.26519298553467 seconds processing time
