kawabonzai
Leader of the Back.
posted October 25, 2008 08:51 PM
2009 .vs. 2008 on the dyno.
Hi there gang,
I thought I'd post up the dyno figures between my 08 and 09 ZX-14. Not much to be expected, differences were not that drastic. I'm just happy I managed to not lose any HP by going with a Carbon Oval.
2008 - 173.64
2009 - 176.70
duncan
posted October 26, 2008 04:42 AM
Did they change anything on the 09 other than colors?
Bently
2012 14r In Blue and no Mods!
posted October 26, 2008 05:58 AM
was this done on the same day?
AZ ZX14
posted October 26, 2008 06:32 AM
D-
Those are pretty close. I would have figured the M10 can would help the HP #'s more.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
kawabonzai
Leader of the Back.
posted October 26, 2008 10:12 AM
quote: was this done on the same day?
Yes, Saturday, but not the same month. I'm not fortunate enough to own 2 ZX-14's at the same time. My 08 was totaled by a VW who pulled out in front of me.
The 08 dyno was about 3 months ago. The 09 dyno was yesterday.
The only thing changed was a few degree cooler, but same dyno and same elevation.
What was weird is that the before after on my 08 was 159/173 for a 14hp gain.
The before after on my 09 was 147/176 for a 29 hp gain.
The 147 run stock on my 09 had me worried, big time. But I'm happy with the end results.
kawabonzai
Leader of the Back.
posted October 26, 2008 10:14 AM
quote: Did they change anything on the 09 other than colors?
Colors only. but I did notice that the 09 had more foam spacing under the rear cowl to keep the end fron touching the top of the rear tail. I have my 08 cowl and the foam spacer is 1/2 as thick.
But so far nothing mechanical that I've seen.
derpie
Dont judge a book by its cover
posted October 26, 2008 12:19 PM
Are they slowing them down by telling the computer to drop the hp ?
87gtNOS
posted October 26, 2008 04:53 PM
Lean out the 08 and watch the HP go UP!!
01 ZX12R
07 ZX14 - YEAH BABY!
03 ZX9R-traded in for the 14!!! June 07!
gilberjj
Friend of Fast
posted October 26, 2008 04:57 PM
hp looks good! 147 would have me worried too!
kawabonzai
Leader of the Back.
posted October 26, 2008 11:18 PM
quote: Are they slowing them down by telling the computer to drop the hp?
The only way the computer can drop HP's is to fiddle with the mapping or fiddle with the secondaries. None of which appear to be happening due to the 09 showing a smidgeon more HP.
quote: Lean out the 08 and watch the HP go UP!!
the 08 was leaned out as far as it could go, it ran head on into a W jetta and was totalled. Hence the new 09.
quote: hp looks good! 147 would have me worried too!
They had problems with the tach wire that day, but peak HP should not have been effected. But I was quaking a bit when I saw that run 3x and no improvement.
I can squeeze a bit more HP (+3) by having it customed mapped. The dyno did show it was running rich from 4200 to 5500 RPM's. Might be worthwhile to do since that's cruising RPM's on long trips ... better gas mileage.
H0mr
posted October 27, 2008 12:41 AM
"The 08 dyno was about 3 months ago. The 09 dyno was yesterday.
The only thing changed was a few degree cooler, but same dyno and same elevation."
I bet there's a little more to it then just air temp. Even optimum air in July can't compete with conditions we see on average in October. Interesting info though, but I am suprised the 08 was even that close. Were both bikes of similiar milege, chain tension, tire pressure, etc.
Not to mention barometric pressure, lots of variables. Most everything runs better in the spring and the fall and the 08 got its turn in the dog days of summer.
2008 SE, Muzzy's M14, PCIII, Adj. lowering links, Heli risers.
87gtNOS
posted October 27, 2008 04:07 AM
Regardless of whether or not the 08 exists or is a wreck now, had it been leaned out some, it would have matched the #'s the 09 made, easily.
01 ZX12R
