posted October 15, 2008 07:58 AM
Nitrous For Shifter/PressureRegulation?
I'd like to swtich over to using a 2.5 lb. nitrous bottle to cover shifting and spraying. However, the shifter side is regulated down to around 130 psi or so currently (CO2). How do you split the shifter side off and regulate it?
06redzx14
posted October 15, 2008 08:03 AM
use a T one side goes to regulator & shifter the other side goes to nitrous solenoid
posted October 15, 2008 08:15 AM
Edited By: Shane661 on 15 Oct 2008 16:15
It looks like I can use the regulator I have then. Just remove it from the co2 valve assembly. So, basically just tee off of the nitrous valve and run a braided line to the regulator. Then I can use the exisiting poly line to the solenoid.
Does that sound about right?
06redzx14
posted October 15, 2008 08:26 AM
what is the psi rating of the poly line? remember that the pressure of the co2 will increase when exposed to heat
posted October 15, 2008 08:35 AM
The poly line is fine for the regulated side. That is the way the CO2 shifter is set up. But I want to run stainless braided line from the nitrous bottle to the regulator, regulate it down to 130 psi, and then go from the there to the solenoid using the poly line.
06redzx14
posted October 15, 2008 08:41 AM
that should be fine that's the way the muzzy kit is setup. looking forward to seeing how the nitrous project comes ou.t are you going to post it to your thread?
posted October 15, 2008 08:44 AM
Yes, I will be posting it. It will probably be a couple of weeks before I can really get into it. I have to get some machining and welding done on the spare swingarm I have....and I'm not sure how quickly the shop works.
