BIKELAND > FORUMS > ZX-14.com > Thread: Lowered and Back RearSets. NEW TOPIC NEW POLL POST REPLY
KawaBonzai
Leader of the Back.
posted October 07, 2008 11:32 AM
Ok, so I did the search thing and found a few threads talking about rearsets, nothing to any major conclusion except the following ...
1. Buell Peg Mod seems to work ok. Only drops, doesn't move back.
2. Vortex seems to install no problem over Sato's.
3. Sato's appear to be finer quality, but install probs, brake switch, heel guards.
4. Pipe/Heel issues with all of them lowered.
I've done the Buell mods on my 08 ZX-14 and would be ok with doing ti again, but I'd thought I'd poll the gang here to see if anything new came up.
Questions ...
The Muzzy Carbon can on the M14 header "appears" to have more gap between the middle pipe and the footpeg. Anyone confirm? (Over the M10 Mega)
Local shop says Vortex can go 2 inches down and back. Reading the instructions here doesn't seem like it could ... (look at pics, only a few holes lower and back.)
http://www.vortexracing.com/clientuploads/RS441_print.pdf
Anyone max out the lowering of any sets and are joyed over the outcome? I'm grasping for any 1/4 inch gain I can get.
Lower and Back is easier on the hips right?
Thanks,
-Bonzai
2009 ZX-14 Candy Lime Green
slates
posted October 07, 2008 12:12 PM
KawaBonzai,
Most of the Sato mount post issues probably came from me. They were the first set I've installed. The Satos are great quality and come pre-assembled. You just need to set them were you want them then locktite everything.
It turned out that the brake pressure switch was fine, but it was the two wires for the brake light for the connectors that were touching after I taped them off, leaving the rear brake on continously. All I had to do was to tape them off separately before taping them together with electrical tape and all was fine. Of course I tried the most difficult solution first instead of testing for the easy ones, which led me to have to bleed the brakes several times with the different pressure switches.
KawaBonzai
Leader of the Back.
posted October 07, 2008 01:38 PM
Slates ... how low and back can you adjust them?
MATTZ14
posted October 07, 2008 09:52 PM
I have Arata and love them, but I'm back and up. Had problem with heals on mids even with stock. There are a couple companys that make oval guards in different colors that fit perfect. I got the faster black ones.
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
slates
posted October 08, 2008 05:54 AM
from Sato's website.
KAWASAKI ZX14 (ZZR1400)
POSITIONS
1 10mm Forward 12.5mm Down*
2 10mm Forward 0 mm
3 0 mm 12.5mm Down*
4 0 mm 0 mm
5 0 mm 12.5mm Up
6 10mm Back 12.5mm Down*
7 10mm Back 0 mm
8 10mm Back 12.5mm Up
note: all measurements are in relation to stock position (0 mm).
* These positions are for drag bikes only since the positions would interfere with the sidestand on a stock ZX14 bike.
KawaBonzai
Leader of the Back.
posted October 08, 2008 03:29 PM
Bummer.
12.5 mm is only 0.4921245 inches?
0.25156116485596 seconds processing time
