BIKELAND > FORUMS > ZX-14.com > Thread: Frame Fitting Gasket NEW TOPIC NEW POLL POST REPLY
NeverKnow
posted October 05, 2008 07:56 AM
When I pulled the tank cowl off a gasket fell to the ground. After searching through BikeBandit images it appears to be an airbox seal (PN 92093-1507). Can anyone tell me the significance of this seal; it appears it was never installed at the factory. What problems may result if it is kept off?
posted October 05, 2008 04:23 PM
got pics?
NeverKnow
posted October 06, 2008 04:03 AM
I have the link.... Frame fitting diagram. Hope this helps
http://www.bikebandit.com/houseofmotorcycles/kawasaki-motorcycle-zx1400c8f-ninja-zx-14-2008/o/m17219
AZ ZX14
posted October 06, 2008 07:07 PM        Edited By: AZ ZX14 on 7 Oct 2008 03:11
Are you sure the gasket is part # 92093? That gasket is from the airbox covers directly above the secondaries. You should not see them when removing the tank cowl. It should be necessary to raise the fuel tank and remove the airbox covers before accessing these gaskets.
If they are not installed you may be pulling in unfiltered air from beneth the fuel tank.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
NeverKnow
posted October 07, 2008 08:02 PM
That is the gasket. Looks like someone left off on install. Feels like the bike is running lean. Would this air commining in under the tank be monitored and the A/F ratio adjusted by the ECU?
AZ ZX14
posted October 07, 2008 08:27 PM
Since you have already taken the tank cowl off my suggestion would be to remove the four bolts holding the fuel tank on. At this point you can lift your tank high enough to get access to the airbox covers without having to take it off. At this point your only a few screws away from reinstalling your gasket. This should eliminate any concern on pulling in dirty air.
Hopefully nothing else was forgotten during assembly. Now is your chance to check it out.
I'm not sure about the ECU adjusting your A/F ratio. I can tell you that I run a PCIII and changed my map when installing the filter and full exhaust.
Maybe someone else can chime in.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
MATTZ14
posted October 07, 2008 09:39 PM        Edited By: MATTZ14 on 8 Oct 2008 05:40
Rubber air filter cover (seal) comes to mind. Correct place and could come off easily if the tabs weren't in correct. Without a pic were all guessing.
Later days, better lays
07 BLACK ZX14 Getting customized waiting for the white stuff to go away
06 BLACK ZX14 GONE Recall was a little late.
NeverKnow
posted October 08, 2008 08:17 PM
Thank you for your assistance; I will take apart this weekend.
0.23896503448486 seconds processing time
