BIKELAND > FORUMS > ZX-14.com > Thread: Honda Releases 2009 Model Lineup Including CBR600 ABS and CBR1000RR ABS NEW TOPIC NEW POLL POST REPLY
posted October 01, 2008 08:17 AM        Edited By: Editor on 1 Oct 2008 17:52
Honda releases their 2009 model lineup with a tweaked CBR600RR featuring available ABS. Also sporting ABS for 2009 is the award winning CBR1000RR. An all new Supermoto arrives in the form of the CRF230M. The DN-01 concept is now available for consumers, and should hit showroom floors soon. Images and full details follow...
Click below the jump straight to each bike:
2009 Honda CBR600RR
2009 Honda CBR1000RR ABS
2009 Honda CRF230M
2009 Honda DN-01
2009 Honda CBR600RR / ABS
A winner on the racetrack and in magazine comparison tests, the light, compact and powerful Honda CBR600RR raises performance standards to new heights in the middleweight class, and is now available with electronic Combined ABS.
Features
NEW FOR 2009
- Increased mid-range power.
- New bodywork for a sleek, race-ready look.
- New lightweight turn signals.
- Radial-mounted monoblock four-piston front calipers.
- CBR600RR ABS equipped with patented, electronically controlled Combined ABS, delivering the benefits of Combined Braking System (CBS) and the benefits of Anti-lock Braking System (ABS).
- Exciting new colors: Red/Black, Black/Bright Green Metallic, Metallic Black, Phoenix, Pearl White/Pearl Blue/Red (2009 special color†).
UNIQUE FEATURES
- Exclusive, MotoGP-derived Unit Pro-Link® Rear Suspension (see Technology Section).
- Dual Stage Fuel Injection System (PGM-DSFI) features two injectors per cylinder (see Technology Section).
- MotoGP-derived Honda Electronic Steering Damper (HESD) (see Technology Section).
- High-revving engine redlines at 15,000 rpm.
- MotoGP-style center-up exhaust system.
- 41mm Honda Multi-Action System (HMAS) inverted front fork (see Technology Section).
- Centrally located fuel tank increases mass centralization for a more compact frame design.
- Line-beam headlights feature three-piece multi -reflector design.
ENGINE / DRIVETRAIN
- Liquid-cooled DOHC 16-valve 599cc four-stroke inline four-cylinder engine features oversquare bore and stroke of 67mm x 42.5mm.
- Idle-Air Control Valve (IACV) minimizes torque reaction and smoothes response to small throttle changes through gradual reductions of air and fuel intake.
- Oil jets located beneath the pistons for extra friction reduction and cooling.
- Iridium-tip spark plugs improve fuel combustion and performance.
- Non-resonance knock sensor maintains optimum spark advance while constantly monitoring combustion performance during mid- to high-rpm operation.
- Nose-mounted, two-stage ram-air system provides high volume of cool air to the airbox for linear power delivery and incredible engine performance.
- Lightweight magnesium head cover.
- Cylinder head features angled valve insets to improve airflow.
- Cylinder head features two springs per intake valve and one spring per exhaust valve for optimum high-rpm valve operation and durability.
- Direct shim-under-bucket valve actuation ensures high-rpm performance and durability with 16,000-mile maintenance intervals.
- Lightweight, forged-aluminum pistons incorporate special shot peening for added strength.
- Nutless connecting rods contribute to reduced weight and quicker acceleration.
- Light neodymium magnet ACG.
- Lightweight stainless-steel four-into-one exhaust features inline-exhaust valve to control exhaust pressure for increased performance.
- Double-pivot tensioner for cam-chain durability.
- Smooth-shifting close-ratio six-speed transmission with ratios closely matched to the engine’s powerband.
CHASSIS / SUSPENSION
- Hollow Fine Die-Cast (DC) frame uses four large castings for ultra light weight (see Technology Section).
- Light aluminum steering stem.
- 41mm inverted HMAS cartridge front fork features spring preload, rebound and compression damping adjustability for precise suspension tuning (see Technology Section).
- Exclusive, MotoGP-derived Unit Pro-Link Rear Suspension (see Technology Section).
- Radial-mounted monoblock four-piston front calipers feature chromium-plated aluminum pistons and squeeze lightweight 310mm floating discs in front and a 220mm rear disc with a single-piston caliper for exceptional stopping power.
- Vertical-piston master-cylinder system produces superior leverage ratio at the front brake lever for higher braking efficiency, excellent feel, and controllability. This layout permits the use of a longer brake lever, which means more braking force with less effort from the rider.
- CBR600RR ABS features Honda’s electronic Combined ABS. This all-new ECM-controlled, hydraulically actuated system provides accurate braking force distribution to both wheels. ABS is controlled by a hydro-electronic unit and stroke simulator to ensure precise operation. Benefits include consistent lever pressure without the pulsing often associated with ABS systems. Application of rear brake does not result in immediate front brake activation unless lock-up is sensed, allowing an experienced rider to use rear brake in a normal manner during spirited riding. Combined ABS components are smaller and lighter than conventional hydraulic ABS designs, and have been located closer to the center of the machine, enhancing mass centralization and reducing unsprung weight.
ADDITIONAL FEATURES
- Industry-leading ergonomic design features maximum rider comfort for minimum fatigue in all riding conditions.
- Centrally mounted 4.8-gallon fuel tank is positioned low in the frame, increasing mass centralization and allowing a more compact design.
- Plastic tank shell cover protects tank and airbox.
- Line-beam headlights feature three-piece multi - reflector design utilizing two H7 bulbs for optimum light distribution and a unique compact design.
- Instrumentation is very compact and features LCD panel with tachometer, odometer, twin tripmeters, speedometer, fuel gauge and clock.
- Attractive, hollow-spoke aluminum-alloy wheels feature race-spec 3.5 x 17.0-inch front and 5.5 x 17.0-inch rear dimensions.
- One-piece fan assembly for maximum cooling efficiency.
- Maintenance-free battery.
- Compact rear-cowl storage compartment for U-type locking devices under the passenger seat (lock not included).
- Pivoting, aerodynamic mirrors.
- Integrated ignition-switch/fork lock for added security.
- Convenient push-to-cancel turn-signal switch.
- Transferable one-year, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
- Purchase of a new, previously unregistered Honda USA–certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Rider’s Club of America® (HRCA®). Visit www.hrca.honda.com for details.
HONDA GENUINE ACCESSORIES
- Color-Matched Passenger Seat Cowl.
- U-Lock.
- CBR® Racing Cycle Cover (indoors).
- Carbon-Fiber Accents.
Specifications
Model: CBR600RR/ CBR600RR ABS
Engine Type: 599cc liquid-cooled inline four-cylinder
Bore and Stroke: 67mm x 42.5mm
Compression ratio: 12.2:1
Valve Train: DOHC; four valves per cylinder
Induction: Dual Stage Fuel Injection (DSFI) with 40mm throttle bodies, Denso 12-hole injectors
Ignition: Computer-controlled digital transistorized with three-dimensional mapping
Transmission: Close-ratio six-speed
Final Drive: #525 O-ring chain
Front Suspension: 41mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.7 inches travel
Rear Suspension: Unit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability; 5.1 inches travel
Front Brakes: Dual radial-mounted four-piston calipers with 310mm discs
Rear Brakes: Single 220mm disc
CBR600RR ABS: Honda electronic Combined ABS
Front Tires: 120/70ZR-17 radial
Rear Tires: 180/55ZR-17 radial
Wheelbase: 53.9 inches
Rake (Caster angle): 23.5°
Trail: 97.7mm (3.86 inches)
Seat Height: 32.3 inches
Fuel Capacity: 4.8 gallons, including 0.9-gallon reserve
Colors (CBR600RR): Red / Black, Black / Bright Green Metallic, Metallic Black, Phoenix, †Pearl White / Pearl Blue / Red
Colors (CBR600RR ABS): Red / Black, Metallic Black
Curb Weight*: 410 pounds(432 pounds CBR600RR ABS)
†Limited color run, less than 500
*Includes all standard equipment, required fluids and full tank of fuel--ready to ride.
The CBR1000RR is the lightest, most compact, and best performing motorcycle in its class, making it the standard against which all other literbikes are measured. And for 2009, it’s available with Honda’s high-tech electronically controlled Combined ABS for the ultimate in sport bike braking performance.
Features
New for 2009
- CBR1000RR ABS equipped with patented, electronically controlled Combined ABS, delivering the benefits of Combined Braking System (CBS) and the benefits of Anti-lock Braking System (ABS). (see Technology Section).
- CBR1000RR ABS features higher output ACG with oil jet hole for improved cooling, higher capacity battery and distinctive silver seat rails.
- Exciting new colors: CBR1000RR – Repsol Edition, Pearl White / Light Silver Metallic, Black: CBR1000RR ABS – Red / Black
Unique Features
- Idle-Air Control Valve (IACV) and Ignition Interrupt Control for idle stability and smoother on/off throttle response.
- Low-mount exhaust system design.
- Patented slipper clutch features cam mechanism to reduce clutch-lever pull.
- 43mm Honda Multi-Action System (HMAS) inverted front fork (see Technology Section).
- Radial-mount front brake calipers combined with radial-actuated master cylinder.
Engine/Drivetrain
- Compact, liquid-cooled DOHC 16-valve 999cc four-stroke inline four-cylinder engine features bore and stroke dimensions of 76mm x 55.1mm.
- Removable cylinder block with Nikasil-coated cylinders.
- Sixteen-valve cylinder head features 30.5mm intake and 24mm exhaust valves with a 12.3:1 compression ratio for efficient combustion and high horsepower.
- Larger titanium intake valves create a lighter valve train and feature double-spring design for optimum performance at high rpm.
- Intake ports use latest shot-peening technology that improves power and torque characteristics.
- Cam-pulser location between the middle cylinders allows a narrower cylinder head and frame.
- Direct shim-under-bucket valve actuation system ensures high-rpm durability and allows 16,000-mile valve maintenance intervals.
- Forged-aluminum thin-domed, high-strength pistons feature molybdenum coating for reduced friction.
- Lightweight nutless connecting rods.
- Dual Stage Fuel Injection (DSFI) (see Technology Section).
- 46mm throttle bodies feature Denso injectors with lightweight valving for faster reaction time and 12 holes per injector to optimize mixture atomization, combustion efficiency and power.
- Auto-enriching system is integrated into Programmed Fuel Injection (PGM-FI) module, eliminating the need for a manual choke.
- Idle Air Control Valve (IACV) minimizes torque reaction and smoothes response to small throttle changes through gradual reductions of air and fuel intake when the throttle is opened and closed.
- Ignition Interrupt Control system works with IACV and FI mapping to enhance driveability.
- Smaller and lighter ECU provides two 3-D fuel-injection maps for each cylinder and two 3-D ignition maps for cylinder pairs, creating ideal fuel mixture and spark-advance settings for superb rideability.
- MotoGP-derived twin-tunnel ram-air system allows a high volume of cooler air to the 9.7-liter airbox for linear power delivery and incredible engine performance.
- Butterfly valves inside the ram-air ducts open and close depending on throttle opening and engine rpm for optimum performance.
- Compact, low-mount exhaust system design reduces rear bodywork size and incorporates exhaust valve and catalyst, contributing to significantly improved mass centralization, and reducing roll and yaw inertia.
- High-capacity radiator incorporates twin cooling fans and allows a more compact cowl for reduced drag coefficient.
- Maintenance-free automatic cam-chain tensioner.
- Starter gears located on the right side to produce narrow engine that allows for increased lean angle.
- Patented slipper-clutch design uses a center cam-assist mechanism for easier actuation. Unlike an ordinary slipper clutch where the pressure plate moves from side to side, the Honda clutch moves both the center cam assist and the pressure plate to provide additional slipper effect.
- Nine-plate clutch is compact and tough, featuring durable friction plate material.
- Durable #530 O-ring–sealed drive chain.
Chassis/Suspension
- Lightweight four-piece Fine Die-Cast twin-spar aluminum frame utilizes latest MotoGP technology (see Technology Section).
- Aluminum subframe is lightweight and easily removed for ease of maintenance.
- MotoGP-derived, next-generation Honda Electronic Steering Damper (HESD) (see Technology Section).
- 43mm inverted aluminum-slider Honda Multi-Action System (HMAS) cartridge front fork features spring preload, rebound and compression damping adjustability, and offers precise action and unparalleled rigidity (see Technology Section).
- Radial-mounted monoblock four-piston front calipers feature chromium-plated aluminum pistons and squeeze lightweight 320mm floating discs in front and a 220mm rear disc with a single-piston caliper for exceptional stopping power.
- CBR1000RR ABS features Honda’s electronic Combined ABS. This all-new ECU-controlled, hydraulically actuated system provides accurate braking force distribution to both wheels. ABS is controlled by a hydroelectronic unit and stroke simulator to ensure precise operation. Benefits include consistent lever pressure without the pulsing often associated with ABS systems. Application of rear brake does not result in immediate front brake activation unless lock-up is sensed, allowing an experienced rider to use rear brake in a normal manner during spirited riding. Combined ABS components are smaller and lighter than conventional hydraulic ABS designs, and have been located nearer to the center of the machine, enhancing mass centralization and reducing unsprung weight.
- Super-light aluminum-alloy hollow-spoke wheels feature race-spec 3.5 x 17-inch front and 6.0 x 17-inch rear dimensions.
- Centrally mounted 4.7-gallon fuel tank is positioned low in the frame, increasing mass centralization and allowing a more compact design. This design positions the rider farther forward for optimum handling.
Additional Features
- Iconic Honda Wing tank badge.
- Lightweight aluminum sidestand.
- Handlebars are repositioned forward for excellent ergonomics.
- High-capacity 400-watt AC generator (non-Combined ABS model).
- High-tech instrument display features tachometer and LCD readouts for speedometer, coolant temperature, odometer, two tripmeters, clock, mpg, average fuel consumption and reserve fuel used.. A low-fuel LED light and shift-indicator light are located above the LCD.
- Line-beam headlight features two-piece reflector design utilizing two H7 bulbs for optimum light distribution and unique compact design.
- LED taillights for lighter weight and improved appearance.
- Front turn signals integrated into folding aerodynamic mirrors.
- Convenient ignition switch/fork lock for added security.
- Maintenance-free high-capacity battery.
Honda Genuine Accessories
- CBR® Racing Cycle Cover. (for indoor use)
- Outdoor cycle cover.
- “E – Cushion”” seat for greater comfort.
Specifications
Engine Type: 999cc liquid-cooled inline four-cylinder
Bore and Stroke: 76mm x 55.1mm
Compression Ratio: 12.3:1
Final Drive: #530 O-ring–sealed chain
Front Suspension: 43mm inverted HMAS cartridge fork with spring preload, rebound and compression damping adjustability; 4.3 inches travel
Rear Suspension: Unit Pro-Link HMAS single shock with spring preload, rebound and compression damping adjustability; 5.4 inches travel
Front Brakes: Dual radial-mounted four-piston calipers with full-floating 320mm discs
Rear Tires: 190/50ZR-17 radial
Wheelbase: 55.4 inches
Rake (Caster angle): 23.3°
Trail: 96.2mm (3.8 inches)
Fuel Capacity: 4.7 gallons, including 1.06-gallon reserve
Colors: Red / Black
Curb Weight*: 439 pounds (461.7 pounds CBR1000RR ABS)
2009 Honda CRF230M
More CRF230M pics below
The all-new CRF230M is street-ready for hours of urban and backroad adventure, with sporty 17-inch wheels and low-profile tires, a torquey, electric-start 223cc engine that boasts exceptional fuel economy.
Features
- Motard-styling with a low and comfortable seat, allows maximum rider movement.
- Aggressive 23.9-degree rake and 91mm of trail provide spirited handling.
- Lightweight 17-inch wheels with sporty low-profile 70-series Dunlop GT401 Arrowmax tires.
- Lightweight Renthal aluminum handlebar with comfortable grips
- CRF®inspired bodywork and graphics with a black frame
ENGINE / DRIVETRAIN
- Dependable 223cc single-cylinder air-cooled four-stroke engine offers plenty of user-friendly power and lots of torque spread over a wide rpm-range.
- 30mm CV carburetor for crisp throttle response.
- Electric start for easy starting.
- Lightweight aluminum crankcase.
- Maintenance-free CD ignition.
- Heavy-duty clutch offers smooth, progressive engagement.
- Smooth-shifting, versatile six-speed transmission.
- Heavy-duty O-ring–sealed chain for durability and reduced maintenance.
- Wide box-section aluminum swingarm provides excellent rigidity to manage traction capability of large rear tire.
- Lightweight semi-double-cradle high-tensile steel frame.
- 37mm leading-axle Showa front fork offers 9.0 inches of suspension travel.
- Heavy-duty Showa rear shock offers 6.6 (167mm) inches of travel for optimum front/rear balance.
- Fork boots keep dirt and moisture away from fork seals.
- Snail-type chain adjusters for easy maintenance.
- Powerful 240mm front disc brake, and 220mm rear disc brake.- Road-ready, lightweight 17-inch wheels—3.0-inch front, 3.5-inch rear—with straight-pull spokes.
- Grippy Dunlop GT401 Arrowmax 110/70-17 front and 130/70- 17 rear tires.
ADDITIONAL FEATURES
- Durable front and rear steel sprockets.
- Wide cleated, folding, self-cleaning footpegs feature rubber-mount pads to minimize vibration and provide secure footing.
- Cleated brake pedal provides excellent grip.
- Quiet, USDA-qualified spark arrester/muffler.
- Maintenance-free sealed battery.
- Ignition switch key for added security.
- Transferable one-year limited warranty; extended coverage available with a Honda Protection Plan.
- Purchase of a new, previously unregistered Honda USA-certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Riders Club of America® (HRCA®). Visit www.hrca.honda.com for details.
AVAILABLE ACCESSORIES
- Rear Rack
- Hand Guard Kit
- Cycle Cover
- Rear Carrier
- Rear Storage Bag
Specifications
Engine Type: 223cc air-cooled single-cylinder four-stroke
Bore and Stroke: 65.5mm x 66.2mm
Compression Ratio: 9.0:1
Valve Train: SOHC; two-valve
Induction: Carburetor 30mm CV
Ignition: CD
Transmission: Six-speed
Final Drive: #520 O-ring–sealed chain; 13T/38T
Front Suspension: 37mm leading-axle Showa fork; 9.0 inches of travel
Rear Suspension: Pro-Link Showa single shock with spring preload adjustability; 6.6 inches of travel
Front Brakes: Single 240mm disc
Rear Brakes: 220mm disc
Front Tires: 110/70-17 Dunlop GT401 Arrowmax
Rear Tires: 130/70-17 Dunlop GT401 Arrowmax
Wheelbase: 52.6 inches (1336mm)
Rake (Caster Angle): 23.9°
Trail: 3.58 inches (91mm)
Seat Height: 31.7 inches (805mm)
Ground Clearance: 9.3 inches (235mm)
Fuel Capacity: 2.3 gallons, including 0.7 gallon reserve
Color: Black
Curb Weight*: 276 pounds
2009 Honda DN-01
Honda's reputation for forging new categories in motorcycling takes its latest form in the radical DN-01. This futuristic machine combines true sporting performance with a fully-automatic transmission, a low seat height and exceptional style.
Features
- Powerful 4-valve, 680cc liquid-cooled V-twin engine.
- HFT transmission is a continuously variable, hydromechanical design that automatically and seamlessly changes drive ratios to produce strong, smooth acceleration. Unlike conventional belt-drive designs, HFT is compact, quiet, no scheduled maintenance, and features two automatic modes and a six-speed manual mode with push-button shifting.
- Low 27.2-inch seat height assures flat-footed confidence when stopped.
- Large-diameter 41mm front fork and single-shock Pro Arm® Rear Suspension (see Technology Section) provide a sporting ride on low-profile Z-rated radial tires.
- Combined ABS (LBS-ABS, see Technology Section) triple-disc brake system for sure-footed braking in varying conditions.
- Combined Braking System (CBS) provides excellent braking power for added confidence in a wide range of operating conditions. CBS applies front braking force whenever the rear brake is operated. On the DN-01, equipped with dual front disc brakes with three-piston calipers and a twin-piston rear caliper, rider application of the front-brake lever activates all six brake pistons in the front calipers. Application of the rear-brake pedal activates the dual pistons of the rear caliper and the center piston of the front-left caliper.
- Anti-Lock Braking System (ABS w/CBS) utilizes modulators—one each on the front and rear wheels—driven directly by specially developed electric motors. In operation, an Electronic Control Unit (ECU) monitors wheel and vehicle speed. If one of both of the wheels approach a locking condition, the modulators, via a signal from the ECU, lower hydraulic pressure by acting directly on the brake piston(s). As wheel speed re-approaches motorcycle speed, the hydraulic pressure is increased. This entire process is repeated numerous times in just one second, resulting in optimal braking pressure and enhanced rider control.
- Beautiful aerodynamic design provides protection from the elements.
ENGINE / DRIVETRAIN
- Compact 680cc, liquid-cooled SOHC 52-degree V-Twin provides substantial torque and power for everyday commuting and spirited backroad riding.
- Programmed Fuel Injection (PGM-FI, see Technology Section) with twin 40mm throttle bodies and high-performance 12-hole injectors provide excellent throttle response and fuel economy while contributing to low emissions.
- Auto enrichment system is integrated into PGM-FI to optimize the air/fuel mixture on cold starts and eliminates the need for a choke.
- ECU-controlled, closed-loop emission control system with oxygen sensor manage the air/fuel mixture and reduce exhaust emissions.
- Front-mounted radiator receives ducted air from fairing shroud to maximize cooling.
- 2-into-1 stainless steel exhaust system with chrome-plated triangular shaped tailpipe is designed to centralize mass for improved handling.
- HFT offers two fully automatic, infinitely variable transmission modes —‘D’ (Drive) mode for ordinary riding, and ‘S’ (Sport) mode for sharper acceleration. In addition, a push-button-selectable, six-speed manual mode allows the rider to upshift/downshift with the simple operation of left thumb-activated buttons.
- The ECU-controlled HFT automatically ‘downshifts’ when climbing steep grades to maintain optimum power.
- HFT provides ‘lock-up’ in cruising mode for maximum fuel economy.
- HFT features button-activated mechanical neutral, permitting engine revving when stopped. Mechanical neutral is automatically engaged whenever the engine is turned off, allowing easy maneuverability.
- Sturdy double-cradle steel tube frame provides exceptional strength and bolt-on seat rail simplifies servicing.
- Stout 41mm front fork with 4.2 inches of supple travel and progressive damping.
- Relaxed 28.5-degree rake and 4.5 inches of trail contribute to comfortable, stretched-out riding position and provide excellent straight-line handling.
- Single shock, Pro Arm Rear Suspension (see Technology Section).
- Combined ABS (LBS-ABS, see Technology Section) with two lightweight 296mm floating front rotors and a single 276mm rear rotor.
- Handsome, lightweight 17-inch 5-spoke cast aluminum wheels with Z-rated 130/70 ZR17 (front) and 190/50 ZR17 (rear) radial tires offer sport-touring traction and comfort in wet and dry riding conditions.
ADDITIONAL FEATURES
- The DN-01’s sleek, aerodynamic bodywork is functional and beautiful.
- Low, polycarbonate windshield allows some air into the cockpit at lower speeds.
- Low 27.2-inch seat height with wide passenger seat provides all-day riding comfort and allows rider to put both feet down at stops or when parking motorcycle.
- Well-placed mirrors provide an excellent rear view.
- Spacious rider footboards enhance riding comfort without compromising cornering performance.
- Handy one-touch, cable-actuated parking brake.
- White LED-backlit, LCD instrument panel provides multi-segment tachometer and large digital speedometer displays with dual-trip calculator, clock, six-segment fuel gauge, plus large turn signal and ‘neutral’ indicators.
- Mass-centralized 4.0-gallon dual-compartment fuel tank with .8-gallon reserve.
- Dual-element headlights provide right-side low beam operation—just like Honda CBRs—while both beams illuminate in high-beam mode. A brilliant multi-segment LED taillight is integrated into the rear cowl.
- Widely spaced turn indicators are mounted on rearview mirrors for style and function.
- Detachable seat provides storage for a U-lock. (Lock not included.)
- Purchase of a new, previously unregistered Honda USA–certified unit by an individual retail user in the United States qualifies the owner for a one-year complimentary membership in the Honda Riders Club of America® (HRCA®). Visit www.hrca.honda.com for details.
- A custom-styled backrest for extra passenger comfort.
- Rugged, full-coverage body cover.
Specifications
Engine Type: 680cc liquid-cooled 52° V-Twin
Bore and Stroke: 81 x 66mm
Compression ratio: 10.0:1
Valve Train: SOHC; four valves per cylinder
Induction: PGM-FI with automatic enrichment circuit, 40mm throttle bodies and 12-hole injectors
Ignition: Digital transistorized with electronic advance
Transmission: HFT continuously variable, hydromechanical two-mode automatic with six-speed manual mode.
Final Drive: Shaft
Front Suspension: 41mm telescopic fork with 4.2 inches travel
Rear Suspension: Pro Arm single-side swingarm with single shock, seven-position spring preload adjustability; 4.7 inches travel
Front Brakes: Combined ABS with dual full-floating 296mm discs and three-piston calipers
Rear Brakes: Combined ABS with single 276mm disc and three-piston caliper
Front Tires: 130/70 ZR17 radial
Rear Tires: 190/50 ZR17 radial
Wheelbase: 63.2 inches
Rake (Caster angle): 28.5°
Trail: 114mm (4.5 inches)
Seat Height: 27.2 inches
Fuel Capacity: 4.0 gallons, including 0.8-gallon reserve
Color: Candy Dark Red, Black
Curb Weight*: 595 pounds
GHOSTMAN
posted October 01, 2008 12:05 PM
Thought the DN-01 would have been a four cylinder. Still a nice bike.
I'm There Whether You See Me Or Not.
posted October 01, 2008 05:12 PM
everyone's got a 250 supermoto 'cept zook now.
posted October 01, 2008 07:41 PM
zook has a 400 superMoto that is getting better gas mileage as the competitor's 250s!!! per both motorcyclist and cycle worlds comparisons.
posted October 01, 2008 08:49 PM        Edited By: CrotchRocket on 2 Oct 2008 04:50
Yeah and the Suzuki 400 goes 14.0s in the 1/4 mile @ 86...
Can you believe that a $20,000.00 Harley road glide is just a .10th faster going 13.90s @ 92mph...
I would take the supermoto over the HD any day ...lol...Does great wheelies and endos too
But, I like the new Honda Supermoto!!!
posted October 02, 2008 06:47 AM
I don't see everyone RUSHING to their local Honda dealership to get the 600RR track weapon with ABS though
But I'm watching.........
Silver Hawk
addition to riding no rehab4me
posted July 27, 2009 07:55 PM
I am looking into a 1000rr with the abs....perfect for mountain curves
2008 Concours ABS 23k miles in a yr Sold
2009 R1 16k miles in a yr Sold
2005 Honda Goldwing..6k miles in 2 months ..Sold
2012 Concours ABS 5k in 1 month..Sold
2011 ZX 10r 2k in 1 month...Sold..
2012 ZX 10R ABS black and red 144 miles as of 4-23-2013 sold.
2013 F6B deluxe sold
Back to the 2012 Connie present
2014 Green and Black ZX14r ..Beast mode!! present.
  Ignore this member    Click here to visit Silver Hawk's homepage.
posted July 27, 2009 08:00 PM
and track days too !
thekaz
spell chequer is bustimicated
posted July 27, 2009 08:29 PM
I was hoping for a CR500R supermoto
ZX11D
Internet Police
posted July 27, 2009 08:56 PM
What, no new VFR? And wtf is that DN-01 abortion? It's really giving me an orgasm just looking at it.
'94 ZX-11
'07 ZX-14
busaisbetter
posted July 27, 2009 11:07 PM        Edited By: busaisbetter on 28 Jul 2009 07:10
1000rr is perfect in every way - and just as comfortable as my zx14 IMO. however major problem is that it uses tooooo much oil and lot of people rate it F because of this reason. 1qt per 1000 miles or less.
Douglas Home
posted July 28, 2009 12:27 AM
The DN-01 ,in my opinion is uglier than a busa!!!!
Doug Mackay Australia
posted July 28, 2009 03:00 AM
I thought there was a new VFR coming?
posted July 28, 2009 05:03 AM
you're a year out!
posted July 28, 2009 10:58 AM
The oil prob has been fixed. But that bike is not as comfortable as a 14, I've been on both bikes.
Silver Hawk
posted July 30, 2009 02:01 AM
the 1000rr abs will be my first super sport bike ever i am pulling all the stops off and paying off the Connie in 4 months...got to have that 1000rr abs...oh and the DN-01 looks on a screen ONLY....up close YUCK......why even bother...yuck to the second power.
Silver Hawk
posted August 04, 2009 09:33 PM
5 dealerships and not one has a 1000rr with ABS...NC sucks...( but they can order me one) ...for fee...whatever..... them bastards...
Silver Hawk
posted August 05, 2009 11:37 PM
SteveWFL...do you have 1000rr with the abs?..and if you have rode one how does it feel...I am tired of you tude videos...
Silver Hawk
posted October 27, 2009 10:56 PM
thanks for the info..SteveWFL
lol
Tarzan
Modulator
posted October 29, 2009 04:18 PM
I have a Repsol with ABS. Feels like normal brakes but dosn't lock in a panic. I havn't been ballsy enough to try and lock em up in the dirt yet.
Country music is ok if you can't hear it.
A day without a wheelie is like a day without sunshine .
Silver Hawk
posted January 12, 2010 12:41 AM
Repsol with ABS..down here the 09's come in only read and black..and I would not try to lock em up in the dirt...fyi....( Repsol paint job)..I have about 3k left on the connie and i have been shopping around for the abs model...only one I found was for 10899.00 vs 13k..so far so good...but i wish they would drop it down a little more seeing how the 08's without ABS are selling for 74 to 7699.00 her in NC...they are selling like hotcakes..
posted January 12, 2010 04:17 AM
I've never sat on ANY 1000cc bike that was as comfortable as a 14. They are two totally different bikes in two different classes.
fasterspider
Red is faster
posted January 12, 2010 08:02 AM
It's 2010, when is the VFR1200F going to be released?
Ray #1
Sold all of my bikes and bought a Toyota rock crawler
Your mama's bedroom smells like ass
Flame On
Fuel Air & Spark
posted January 12, 2010 08:13 AM
I guess hiting the floors early is a thing of the past
77 RD 400
80 GS1000 GT
06 ZX14
Silver Hawk
posted January 12, 2010 07:48 PM
this Spring is my guess
0.22390699386597 seconds processing time
