BIKELAND > FORUMS > ZX-14.com > Thread: Mounting Shifter Solenoid/Location? NEW TOPIC NEW POLL POST REPLY
posted October 01, 2008 03:26 AM
I was wondering where everyone is locating their air shifter solenoids? I plan to mount mine directly to the ram...in the off season. I would like to mount it under the seat area right now, but was wondering if that is too far away.
The general consensus seems to be to mount the solenoid as close to the ram as possible. It seems to me that if you don't have any air leaks it should still work ok mounted a couple of feet away.
06redzx14
posted October 01, 2008 05:40 AM
mine is right behind the gill on the right side. cut 16" of hose and use that as the max away from the ram
NOX
PMRA / TMRC Super Street 4022
posted October 01, 2008 06:03 AM
On the ram. Only place to put it.
Its a speed thing. You want it as close as possible. I spoke with the companies that make the stuff, ...........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted October 01, 2008 06:06 AM
Obviously that is the preferred location. But I need to get the cylinder machined to make it fit the way I want it to; I don't have time to get that done before Friday.
I'll do the best I can with what I have....
smokinzx14
posted October 01, 2008 07:22 AM
Mines next to the battery ...Never missed a shift or had a so called slow shift ... It's only 4 or 5 inches of hose .
posted October 01, 2008 07:26 AM
I didn't even think of that...under the tank in the compartment, to the left of the battery, correct?
smokinzx14
posted October 01, 2008 07:35 AM
Yes ... There is a hole in the bottom of the battery box to run the hose out of .. It's pretty handy ...
posted October 01, 2008 07:41 AM
Excellent, thanks!
Cajunboyz
posted October 01, 2008 07:42 AM
Mines under the tank by the battery with the red "bleed" button facing down. After finishing, its easy to bleed it down through the solenoid.
jarhead
posted October 05, 2008 05:32 PM
You should not have to allow more time to shift as long as you stay within 16" like 06 said. On the cylinder is of course best for function because you can actually start to decrease kill time, I just don't care for the look, no offense guys. You can go from 65 milli-seconds down to as little as 40 milli-seconds with it on the cylinder.
0.34892988204956 seconds processing time
