Aaron00
posted September 19, 2008 09:44 AM
Edited By: Aaron00 on 19 Sep 2008 17:56
PCIII Grounding
Howdy gent's
Was wondering if anybody knew what guage wire the grounding was on the pc? Reason being, I am having grounding issues with its current location and figure I would be better off splicing and soldering more wire to it and running it to the other side of the bike where the battery ground off to.
Very much appreciated! This is my first time at this so hopefully I get it right
Sin City
posted September 19, 2008 10:20 AM
You can also mount the pc under the seat area (although it isn't shown in the directions). Then there is adequate distance to reach the battery ground:
The only issue is that if you add an ignition module it won't have long enough cables to mount in that location. I mounted my pc under the seat so that I could access it quickly to alter the map. I may move it up front, along with the igntion module, now that I have an lcd to switch maps.
Aaron00
posted September 19, 2008 10:35 AM
Hey Shane!
How hard was it to move it under the seat? I may actually give this a shot before splicing any wires.
Sin City
posted September 19, 2008 10:48 AM
Well, I had to prop the tank up to run the cables underneath. Other than that, it should be close to the same. Obviously you will have to disconnect and reroute the connections.
I had my throttle bodies out when I did mine. So look at the connectors and make sure you can situate them "easily". I have big hands, so I was glad I had it opened up when I did it.
Other than that, no issues, works great! I used the grounding block right off of the battery.
