BIKELAND > FORUMS > ZX-14.com > Thread: Its Hot!!! Its Hot!!! NEW TOPIC NEW POLL POST REPLY
killakaw4life
posted September 15, 2008 08:41 PM
The bike is just about running hot. Yesturday, I took it out about 10 miles and the temp bars got all the way up to the last notch before hot. Being I just got the bike I decided to do some checking. The coolant in there was extremely deep green. Looked kinda funny so I flushed it out and put some fresh coolant in it. 50/50 mix.
Well took it out afterwards and guess what. same thing. And the kicker is that it was 70 sumthin outside.
What do I need to do next? I haven't heard of many thermostats going bad on these things but thats what I'm thinking of replacing next.
Also the cooling fan has a Muzzy aftermarket blade. What I don't know is if there is suppose to be a shroud around it. It has just the fan and thats it. Throws a lot of air but don't know if it is really pulling anything through the radiator.
Can anyone help?
Scalded Dawg
posted September 15, 2008 09:07 PM        Edited By: Scalded Dawg on 16 Sep 2008 05:24
I am curious, you got a TRE or "flies out"
mine RAN hot (past tense)...took that turd TRE off. Out with the flies and remapped.
TRE and "flies out" is WAY ASS LEAN in the 3000-4000 rpm range...
LEAN=HOT
Remap is a must. I think some (just some, not ALL) people may not know that.
Cool and smooth now.
zerotahero
posted September 15, 2008 09:16 PM
mine runs hot to, but not that hot even when it was in the 90's and i was in stop and go traffic mine did not run that hot crazy. good luck though.
nczx14
posted September 15, 2008 09:48 PM
I'd try the thermostat first.
2K7 everything possible without going in the engine.
BobC
posted September 16, 2008 12:08 AM
Mine ran hot until I junked the OE exhaust and fitted a four-into-one. Lots of owners have found the same thing.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
sweetfa65
posted September 16, 2008 04:25 AM
Just curious, do you have a radiator guard fitted? Reason I ask is that I've just gone through a process of creating my own guards, after fitting one that slowed the air down way too much. I noticed a temp increase of at least one bar as soon as I fitted it. Do a search on "ZX14 Stainless radiator guards" if you want to know more.
'2013' SE Spark Black & Golden Blazed Green ZX14R. Bog stock after trading my 07 ZX14.
street racer
posted September 16, 2008 05:01 AM
I drained the coolant and replaced it with water wetter and distilled water. Easy fix to much cooler running. You can also remove the "spats" from the front fender if you want more air over the radiator while moving. I might do that next summer but sure dont need it now. Mine has never gone over one bar from the center. Riding in 65 degrees it runs one bar below center.
bawls
re-learning to ride
posted September 16, 2008 05:42 AM
I'm still wanting to try the whole water wetter thing.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Sticks_n_Stones
posted September 16, 2008 05:49 AM
Water wetter works well in warm weather. heh heh now say that 10 times fast.
Its a recurring theme on here about the high temps, apparently its just a gauge issue you can ignore it. Mine was always one bar from the top or AT the top until I broke it in. Even then it still ran 2 bars from the top until I put the Muzzy full exhuast on. Rarely gets up there any more, stays around the middle. Guys have used infrared thermometers to verify that some bikes have bad or overenthusiastic gauges.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
killakaw4life
posted September 16, 2008 06:23 AM
Here are the mods: Muzzy full exhaust, flies out, ivan tre (just the timing retard one), pcIII, dropped, stretched, muzzy fan. ummmmmmm I think thats it.
Guess I'll try the water wetter, thermostat, and I guess I also need to remap the PCIII cause I bought the bike with all that stuff on it..
Now I just need the line the hooks to the PCIII from a computer. Are All of those the same? I may be able to borrow one.
nczx14
posted September 16, 2008 07:29 AM        Edited By: nczx14 on 16 Sep 2008 16:45
"The USB cable is a USB to Mini-B cable and it can be purchased at any computer store." That's straight off of DynoJets website.
killakaw4life
posted September 16, 2008 09:39 AM
Naw No radiator gaurd
Killjoy_1
posted September 16, 2008 09:49 AM
I have an 07 stock ZX-14 and I roll through Nevada and Death Valley on my hottest runs. Ambient temps on one trip was 117 at Furnace Creek and the other was 122 at Badwater Basin. I have not experienced the overheating problem that many of you encounter, I do feel the heat coming off the engine. My temp gauge will go to the mark below the H but never has it gone to high temp, even in stop and go Vegas traffic this summer. I recently did have to add coolant to the bottle. I wonder what is different about my ride than others? Buddy of mine has an 07 like mine and he added a second fan. Never has had any problems either. One thread or article I read mentioned something about the pads underneath the plastics being positioned incorrectly and it contributed to overheating due to incorrect airflow. Something for others to check?
killakaw4life
posted September 16, 2008 10:03 AM
Got the cords and baterry stuff for the PCIII on the way. Can anyone run me through the process of programming the thing. also I have heard a lot on hear about the TPS setting. Need that info 2.
killakaw4life
posted September 16, 2008 10:04 AM
LEAN=HOT
Gonna remove tonight and test. then should be able to reproggram tomorrow and see what that does.
street racer
posted September 16, 2008 02:19 PM
If you drain the coolant to add water and water wetter, BEWARE, it really comes shooting out the coolant drain plug. Instead of draining down slowly it shoots straight out towards the side.
MJ
posted September 16, 2008 04:09 PM
Same here..my 14 will go to one bar below the H in hot weather and thats it. Has never overheated in triple digit temps sitting in traffic, and I've never had to add anything to it. Every kawi I've ever owned has used the whole range of the gauge..thats how they're designed. If you want a gauge that never goes over halfway get a busa. The bikes will both be running the same temps, but the busa gauge will make you feel alot better if you're the worrying type
killakaw4life
posted September 16, 2008 04:38 PM
Ok, Update. Got the thing remapped and still having the same issue.
I will go and borrow a laser temp gun and check the temp the actual running temp of the thing. Will get back with you guys when thats done.
dcjens
Wet side of Washington
posted September 16, 2008 04:41 PM
Ive researched getting a second fan with brackets from a newer concours 14. They come with 2 fans. My dealer here was retarded that day so I got a "I dunno" as far as a firm price. Each piece had to be ordered separately. I also wondered about a shroud. Mine stays at one square above or below. Just like the speedo- Its just wrong... dont worry about it. Chew care-free gum when you ride?
Sticks...I had to go back to rubber baby buggy bumpers to get warmed up!
Black 06
joemugg
posted September 16, 2008 05:24 PM
Just a note, when all the bars on the temp gauge are lit, you're still not actually overheating. If/when the bike gets too hot the display starts flashing OVERHEAT kind of like when you run the fuel level all the way down and it starts flashing that its out of fuel.
'97 GSXR600 street sweeper
killakaw4life
posted September 17, 2008 09:41 AM
Top left of rad if looking at the bike from the front is at 238 degrees
Top right at 180
bottom right at 220
bottom left at 234
engine casing at head at 255
I don't have a manual but is that inline with what the running tempsshould be?
Sticks_n_Stones
posted September 17, 2008 02:52 PM
No, thats too hot. Radiator should be in the 205-215 range at the upper hose feed (rear brake side). Was your fan on? Sounds like you might have a bad thermostat...
But first, check with another at operating temp 14. Your heat gun might be off.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
killakaw4life
posted September 17, 2008 10:21 PM
The fan was on and never turns off unless I'm at highway speeds and the notch goes to only one above half mark. Don't know anyone around here that has a 14. my friend stays in new orleans. seen a guy the other day with a 14. maybe I will run into him soon.
Thanks for the input
0.21740102767944 seconds processing time
