BIKELAND > FORUMS > ZX-14.com > Thread: Track runs NEW TOPIC NEW POLL POST REPLY
neverknow
posted September 10, 2008 06:07 PM
Track runs
I am interested in running some ΒΌ mile runs at Atco or Englishtown. How do I get started and what is the process to register?
billeason
posted September 10, 2008 06:24 PM
Just show up on the race day! Check their website for dates,and when you get to gates tell the attendent that your there to run street bike. They will tell you where to go. You will then have to go to a little building called tech. They will check that you have a helmit/gloves leathers and numbers on the bike so the tower knows who you are! The tracks you have listed will require full leathers, which you should want to wear anyway. Hope this helps but its real easy and have fun /good luck you will be hooked once you go....... Bill
bill eason
bawls
re-learning to ride
posted September 10, 2008 08:04 PM
If you don't have a set of leathers and don't want to spend the money on them just yet, you can always check around for 1/8th mile tracks. Most of them don't require leathers unless you go really fast. The first half of the 1/4 is the important part anyway
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
posted September 10, 2008 08:38 PM        Edited By: CrotchRocket on 10 Sep 2008 21:41
As Bill said, You need leather jacket and pants, boots over the ankle, leather gloves, snell & dot approved helmet and ignition cut off cord - that can be made from a coil key chain and a small sheet metal screw connected to the red ignition off switch...
If you go faster than 10.0 and or 125mph then you will need to take your test for the NHRA motorcycle DragRace License, the paper work you need is available in the tower @ RacewayPark, Englishtown, NJ...
When you pull up to the gate @ Englishtown, tell them motorcycle test / tune...$ 30 then go straight to the tech shack with a valid drivers license and tell them you run 10.50s...They will check out your equipment...
The next best day to go for bikes is saturday September 20, 2008 which is The Orient Express Top Street Bike points series event, which usually has about 30+ bikes present...You dont need to be signed up for the points to compete...Or You can buy a test / tune tech card and make your time runs with all the bikes!!!
Just go and have fun, I guarrentee you will be hooked...Look for my blue zx12 and introduce yourself...i'll go over the burnout, staging, timing lights, finish line, turn off at the end of the track, and where to get your timeslip...
See you on September 20th @ Englishtown...
Dont worry about how fast you go, as long as you get faster than your first pass!!!
neverknow
posted September 11, 2008 08:54 PM
Thank you for the feedback. I appreciate the support and the assistance. I will look you up in Englishtown.
neverknow
posted September 12, 2008 06:28 AM
BTW - Can anyone recommend a decent set of leathers for an occasional track day?
NINJA12
posted September 12, 2008 08:42 AM        Edited By: NINJA12 on 12 Sep 2008 09:44
I bought this suit at least 2 year ago , still going strong.
Two of my buddies got them last year. One has been track tested and passed with an "A".
http://cgi.ebay.com/ebaymotors/2PC-PHANTOM-LEATHER-MOTORCYCLE-RACING-RACE-SUIT-BLACK_W0QQcmdZViewItemQQcategoryZ6750QQihZ023QQitemZ360088126117QQtcZphoto
They run a little small.
shane661
posted September 12, 2008 08:48 AM
Those are the same leathers that MPS sells for $349. Looks like a hell of a bargain!
I am looking for a drag racing suit myself, and these might be the ticket.
NINJA12
posted September 12, 2008 11:21 AM
One of my friends didn't think so when he bought his MPS set at Prostar.
I when to the truck and pulled my leathers out. EXACT SAME!
0.24630880355835 seconds processing time
