BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 rims. on ZX10. ???? NEW TOPIC NEW POLL POST REPLY
BIKEGOD
I'm lost???
posted September 08, 2008 07:25 AM
What do you guys think.
Can it be done? and if so. How???
I have a set of chrome rims for my zx14. However, they are to micuh in weight. SO...........
I was thinking if I could some how fit them on my zx10.
Both are 2006 models.
I'm thinking..................I could possibly put zx10 wheel bearings in the wheels. change the calipers to zx14 calipers, and keep the zx14 rotors.
That might work....
ANYONE??????????????
I'm a friend of your mom's,
Get in the car !
slates
posted September 08, 2008 10:52 AM
Smokin...Dubious...Billeason or any other expert, please help this guy out.
Carrozzeria told me my 14 wheels would not fit a 10 or any other bike.....Why??
BIKEGOD
I'm lost???
posted September 08, 2008 11:14 AM
I'm tryin' anything.
I know, someone on here knows. "after all the mods I've seen these guys do"
I'm just hopin' they'll see the post.
Get in the car !
flatoutbu
posted September 08, 2008 11:38 AM
I don't want to be a smart ass but why would you want to put heavier wheels on a bike with less power? It looks like kawi took man hole covers and put tires around them for the 14.
I have heard of 10 wheels being put on the front of the 14 but they have a different size axle for the back. You might get around switching bearings...experment and tell us your results, I'm curious myself.
06 Blue 14
9.008 at 153mph @ 195 suited
gilberjj
Friend of Fast
posted September 08, 2008 12:44 PM
i wouldn't mind putting zx10 wheels on my 14.......
flatoutbu: how hard is that to get the 10 wheels on the 14?
shane661
posted September 08, 2008 12:47 PM
You have both bikes and sets of wheels at your disposal. It sounds like you are in a better position to find a solution than the rest of us....
BIKEGOD
I'm lost???
posted September 09, 2008 03:16 AM
Hmmmmmmm..............I guess I'll have to try it out. When I do I'll post the "procedure"
Get in the car !
Peno
Peno
posted September 09, 2008 04:47 AM
Good Luck with it. Me personally would rather have the 10 on the front its a pain working around those Y's and rotors trying to clean the front
flatoutbu
posted September 09, 2008 04:58 AM
As long as axle size is the same..that is the hardest part. All the rest of it would just be spacing to get the calipers right.
06 Blue 14
posted September 09, 2008 08:01 AM
You will have to check the kawi part numbers for brgs.
I can't remember 100%, but before I went with the GSXR1000 wheels, I looked at zx10 wheels for the 14.
If I remember correctly, the 06 zx10 frt axle is same diameter as the frt axle on the 14, and the 05 zx10 rear axle was same diameter as the zx14.
I am not 100% sure, but beleive the spacing will be the same for those conversions, for calipers, and rotor diameters
Checking out the parts fiche's will assist and save frustration and some time wrenching
justoyz2
Justoyz Racing
posted September 09, 2008 02:23 PM
Ben there done that! The wheels will fit between the forks and the swing arm. You will need a machinist to create some spacers and an axle for the rear and the front.
The zx14 wheels carry a larger axle. The aren't any bearings that will fit in the rim to match the orifice of the bearings, nor will you find it the reverse way. I took my stuff to NAPA and they couldn't match up a smaller bearing with a larger hole......
You can change the forks and the axle then it will work.
2012 zx14R-blue,2012 zx14R-black, 2014 zx14Trbo, 2011 zx10R, 2007 zx10 Turbo.....
0.21972799301147 seconds processing time
