BIKELAND > FORUMS > ZX-14.com > Thread: Anyone try VP 4.2 NEW TOPIC NEW POLL POST REPLY
Pat Dietrich
posted September 04, 2008 04:59 PM
Anyone try VP 4.2
WHats your results? My bike was mapped on the original U4 so whats anyones opinions on this 4.2 vs the old or even against pump fuel? Thinking of running friday and can get some 4.2 if your seeing good results
madboost
posted September 04, 2008 05:29 PM        Edited By: madboost on 4 Sep 2008 18:30
u4.2 is good on the spray its 102 octane, throw some mr9/mr11 in there you'll fly
but as far as a/f goes you shouldnt see much difference betwenn u4 and u4.2
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
Nox
PMRA / TMRC Super Street 4022
posted September 05, 2008 06:47 AM
I love it.
call VP, you will have to adjust your map just a hair for it.........
Once I did, i run the same as I did on the old U4. I have run 124 mph in the 1/8 mile, with stock internal parts on a zx12, with no spray.
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
Pat Dietrich
posted September 06, 2008 05:20 AM
Well, didnt get to take the bike but i do have a 5 gal. can so before i go ill take the bike to ryan s and get the map adjusted. ill post results on the difference in the map from u4 to 4.2. thanks Nox.
JohnnyRocketZX14
posted September 06, 2008 08:11 AM
hmmm, well brocks, muzzy, & schnitz told me never to spray with VP U4.2 and brocks said never to run it that it was junk (exact words) that only if the class i was racing in required it should i use it. MR9 is no longer being made so if you get some it will be shelf stock but MR11 and MRX01 (for spray) is the best(also cost the most)
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
madboost
posted September 06, 2008 02:55 PM
u4.2 is 102 octane dont see why you cant spray on it, mr9 is 87, mrxo1 is 92 octane so i def wouldnt spray on that.
9.44@144 w 1.5060ft
shane661
posted September 06, 2008 02:57 PM
I love it.
Nox, what is your mph difference with/without the fuel?
posted September 06, 2008 05:24 PM
ive run a few 120s on pump gas, and im still working on my fuel map, launch, ect
JohnnyRocketZX14
posted September 06, 2008 09:50 PM
1. well i think caution should be used whenever spray is used on any Oxygenated fuel, 2. i believe they were also referring only to small shots (50 or less) of course proper AFR is the key and 3. MRX01 is 98 octane which is perfect for small shots and MR11 is 90 great for all motor runs. i was told that U4.2 has a detonation problem when used with nos, brocks said they have seen several motors damaged because of it..............................the fuel i want try is StreetBlaze 100, has anyone seen it or tried it??? claims to have 14% more power than premium 91 octane fuel
07 ZX14
madboost
posted September 07, 2008 03:37 PM
any fuel thats claimed to have more power is oxygenated
9.44@144 w 1.5060ft
FIREBRAND74
posted September 07, 2008 07:57 PM
my bike was dynoed and mapped by adams performance using 4.2 with spray . I haven't had any problems . What kind of damage was brock refering to?
Nox
posted September 08, 2008 06:05 AM
I love it.
I have never quit running u4 since I started using it in 2004. When I started then, I gained 4 mph in the 1000ft, 3 mph in the 1/8, and 2 tenths...........
I short shifted my bike sat night in a 5.90 class, 700 rpm low on the shift light.........
ran a 3.78 330..........
Stock internals.
Its GUD!!!!
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Conway Cycle
Syed Leathers
Pat Dietrich
posted September 08, 2008 04:19 PM
And thats the key. if your bike is dynoed and mapped with the fuel using the nos and its done right, there should not be any detonation problem period. Especially since the 4.2 is over 100 octane i think the story has to be a little mixed up.
posted September 08, 2008 05:20 PM
if you go by normal jetting and dont test, an oxy fuel would be way lean in a nitrous application right? mapped correctly, im guessing theres a lot more fuel added for a set amount of nitrous compared to non oxy fuel.
if you run c16 and nitrous really lean you will get damage too right?
JohnnyRocketZX14
posted September 08, 2008 07:36 PM
lean/rich had nothing to do with the engine damage but detonation is where the problem was. Now that would normally be due to low octane fuel. Im am just mentioning what was just told to me last week when i questioned three different performance companies about my dyno results with nitrous. i am no expert, but the one thing they all agreed on was dont use U4.2 unless you compete in a class that requires it. especially don't spray with it. Wish i had asked more details as too why a fuel with appropriate octane rating had a detonation problem when used with nitrous but i didn't. I figured someone else would chime in and further explain by now
07 ZX14
madboost
posted September 09, 2008 04:53 AM
alot of people i know spray on u4.2 with no issues
9.44@144 w 1.5060ft
SteddyTeddy
posted September 09, 2008 04:55 AM
I ran through a can of StreetBlaze 103 a while back spraying. On motor I didn't get any real increase near as good as running U4.
0.42418479919434 seconds processing time
