BIKELAND > FORUMS > ZX-14.com > Thread: Tapping into TPS/RPM From PCUSB? NEW TOPIC NEW POLL POST REPLY
shane661
posted August 31, 2008 04:52 PM
I'm getting ready to hook up my data logger, but am not certain which wires I want to use for tps and rpm. I have heard that you can actually tap into these signals on the Power Commander wiring harness, as opposed to the factory one.
Has anyone done this, and if so, which wires did you attach to? I suspect these will be fairly clear signals.
posted August 31, 2008 09:33 PM
interesting ideas Shane. I wonder if you could also get injector duty cycle from that?
shane661
posted September 01, 2008 01:23 AM        Edited By: shane661 on 1 Sep 2008 03:52
I think so. Now that I think about it more, it would be ideal to tap into the cable for the lcd, since it is detached. I am going to investigate more when I can get ahold of Dynojet.
posted September 01, 2008 07:01 AM
the lcd displays injector duty cycle so i would say yes
shane661
posted September 01, 2008 07:48 AM
I did find this info over on Psychobike:
"Hey guys. didnt get the good clear signal i wanted off that wire so i called power comander and man did i ever get a easy answer....The grey wire on the wideband, the pc3usb also uses a grey wire for TP so just link those together in the harness and you get a real clear signal. EASY EASY to do. "
I can't confirm this as working, but it's just perhaps once piece of the puzzle.
shane661
posted September 01, 2008 08:09 AM        Edited By: shane661 on 1 Sep 2008 09:10
I would imagine this subject has been done to death somewhere. I wish I knew where! I checked the Innovate message board, but didn't get much good information.
ninja12
posted September 02, 2008 11:22 AM
Are you saying both grey wires are TPS, or the wideband gives RPM and USB gives TPS.
shane661
posted September 02, 2008 11:30 AM
I'm not saying it works or not...I found the above information posted on Psychobike. Dynojet might confirm, but it seems that their pinouts are top secret??
Apparently the grey wire on both the wideband and power commander are both tps.
The lcd displays tps, rpm, and injector cycle. What signals are being sent via the cable, I don't know. That's where the pinout is needed.
flatoutbu
posted September 02, 2008 12:14 PM
I know the white wire with the red stripe is the one we used to get a clear signal on the dyno. We checked almost every wire and couldn't get one to work...called DJ and ta da...one of the last ones we didnt try.
06 Blue 14
9.008 at 153mph @ 195 suited
shane661
posted September 02, 2008 12:16 PM
Clear signal for what? RPM?
posted September 02, 2008 03:40 PM
I emailed DJ about duty cycle on my pc3r a couple days ago... no reply yet
flatoutbu
posted September 03, 2008 08:55 AM
Yes...sorry, i just skimmed thru the post. Is that what you was looking for?
06 Blue 14
shane661
posted September 03, 2008 01:14 PM
The white wire with red stripe on the pcusb?
If so, that is great news. That would mean that rpm and tps points have been determined.
shane661
posted September 03, 2008 01:17 PM
Yes, I was looking for rpm and tps from the power commander harness. It looks like we may have found those two.
If the information I found on tps is accurate and your info is for the rpm, then we can tap those points for a data logger it would seem...without hunting for a clean signal on the factory harness. At least that is what I am hoping to be the case.
flatoutbu
posted September 04, 2008 06:01 AM
I'm sorry guess i should have read your post a little better. The wire i was talking about was the one off the factory wiring harness.....but it might be the same wire for the pc. Sorry i can't be more help.
06 Blue 14
E1000
posted September 16, 2008 01:33 PM        Edited By: E1000 on 16 Sep 2008 21:37
hey guys, the grey wire taps into the yellow & white wire on the main throttle sensor (the lower sensor on the throttle body). the white & red wire is for external log. the orange wire taps into the negative side of any coil.
1st GEN ZX14
few bolt ons
87gtNOS
posted September 18, 2008 06:17 PM
Shane, do you have the PC3 hub? I think you would need it to tap into it.
I have lots of email conversations with a couple of the dynojet guys. I use a PC3, hub, timing module and my LCD on my snowmobile. It has nitrous, etc....I use my LCD on the bike in the summer!
Right now, I am just too tired to think about it....sorry. I need sleep!
01 ZX12R
posted September 19, 2008 12:01 AM
hey shane,
you MUST get duty cycle downstream of the Powercommander as that's what the PC does, modify duty cycle of the ECU.
posted September 19, 2008 04:12 AM
87gtNOS:
Yes, I have a hub. If you can find any of the info from Dynojet that would be fantastic.
Karl:
Thanks for that tip! That is probably one of those little details that many people forget.
posted September 19, 2008 06:06 AM
87gtNOS:
Karl:
"many people" includes my dumb ass.
I was puzzled why DC was the same no matter what i put in the fuel matrix on the PC3r...
johns
posted September 20, 2008 06:26 AM
good information, I just ordered a Innovate LM-2 and am going to need it. I planned on using the same wire taps as my Raptor shift light for the RPM but had not looked into where to tap for the TP signal.
2006 ZX-14 (sold)
2012 ZX-14R (Brock's Perf. project bike Louisville Slugger)
2013 Honda VFR1200F
2003 124 C.I. H.D. Super glide
0.44327616691589 seconds processing time
