BIKELAND > FORUMS > ZX-14.com > Thread: F I Light. NEW TOPIC NEW POLL POST REPLY
kimski2001
posted August 26, 2008 04:47 AM
F I Light.
last night i was putting my motor back in and deciced while it was out i would pull the rod that goes through the throttle bodies out,the one the secondary butterflies are on.now i have an f.i light on.i know it has something to do with the sensor on the right side of the bike cause i have an extra set of and i hooked them up(not on the bike and it goes off!any help is appreciated.
1st14injax
Superman T
posted August 26, 2008 07:19 AM
Kimski2001-I don't fully understand your question/situation to give some advice to ya. Can you please add some more details for clarity?
kimski2001
posted August 26, 2008 07:34 AM        Edited By: kimski2001 on 26 Aug 2008 08:35
While the bike was running we unplugged the throttle position sensor, hooked it up to a extra set of throttle bodies(that are not on the bike) that i have,and the fi light went out.what im trying to figure out is there anyway around this light flashing?
1st14injax
Sticks_n_Stones
posted August 26, 2008 08:54 AM
Yeah, but your secondary flies rod back in and reattach the stepper motor. Unplugging the stepper motor will cause a fault code to trip. Suppose you could leave it plugged in, but there might be an issue with it needing the spring to return the motor to closed after it opens.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
kimski2001
posted August 26, 2008 08:03 PM
Thanks guys for the help,i put my extra set in and lights out.
1st14injax
0.21322417259216 seconds processing time
