BIKELAND > FORUMS > ZX-14.com > Thread: ZX14 Stock Dyno numbers NEW TOPIC NEW POLL POST REPLY
neverknow
posted August 25, 2008 05:17 PM
Does anyone have numbers or a picture of their Dyno printout from a stock motor Dyno run? Interested to see if stock motors have consistent build quality.
200hp_zx14
posted August 25, 2008 05:51 PM
Stock will vary a lot actually. I'm sure you would see anywhere from 160 to 170 at the wheel from a stock bike. It all depends on the dyno and elevation
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
smokehouse4444
XX to ZX
posted August 25, 2008 07:08 PM
Yeah, my 08 showed 161 hp and 100 ft/lbs torque on a hot and humid morning in central Texas. I was quite disappointed. Done by a very respected dyno/person. However, the first night I hit 1000 miles and opened her up, I was challenged by an 08 Busa and an 08 ZX-10 on a nice strip of highway. Pulled the 10 a little and slowly left him. The Busa jumped me but I caught and passed him around 150 before we shut it down. So go figure. At 161hp? Doesn't make sense, does it.
2008 Atomic Silver ZX-14, Brock's this and that, some other stuff, 260 in full gear, powered by Cheese
2005 Ducati 999 with all the goodies
the14thninja
Show and Go
posted August 25, 2008 07:12 PM
dynos don't account for the zx14's ram air system, that's why the busa may show more horsepower on the dyno, but the 14 wins on the track.
I live to ride and ride to live
neverknow
posted August 25, 2008 08:44 PM
What about the AFR throughout the power band at operating temps. Does the Dyno graph indicate anywhere close to ideal (14.7 to 1) for standard fuel and air density. My new 08 ZX14 seems to run lean between 3 to 4 thousand; experiencing engine and bar vibration. Anyone have AFR numbers from their Dyno run?
H0mr
posted August 25, 2008 10:04 PM
I don't think the 08 run lean anywhere. They were set up pretty far from the factory....
2008 SE, Muzzy's M14, PCIII, Adj. lowering links, Heli risers.
KawaBonzai
Leader of the Back.
posted August 26, 2008 12:13 AM        Edited By: KawaBonzai on 26 Aug 2008 01:13
My stock ran 159.5 before pipes, 174 after ...
http://www.zx-14.info/bonzai/20080626_08ZX14_M14_BMC_PC3_FliesOut.jpg
2009 ZX-14 Candy Lime Green
salsa1
posted August 26, 2008 05:33 AM
peak horsepower will not describe acuurately the energy released throughout the rev range of a bike...torque plays a roll...and other factors..
Peak hp is that ; peak hp..sure it gives you a strong factor to aasert a bikes power but not the only one in play on a given run...
If you look a at a dyno sheet you will see variances in hp between two bikes that say as much or more (how they unfold) than just the peak hp produced by the two...
ability to rev...internal light parts also play a roll in my estimation of how quick a bike is...
my opinion..from studying the topic over the years...your opinion may vary..but I know peak hp is not the only measuring factor to determine total energy output on a given run....
also launching technique..rider skill weight ect..but that is beyond the scope of this thread probably...
nice to have a high peak hp..no doubt...
have fun... ...
Salsa1
ninjanick
'08 ZX14 (Blue)
posted August 26, 2008 01:24 PM
My '08 got 170rwhp and 104/lbs.ft torque completely stock.
neverknow
posted August 26, 2008 02:14 PM
Kawabonzai - After reviewing your graph you are lean below 5 k in comparison to the remaining numbers. Did you feel this on take off? You dialed your bike in nice with your upgrades. I believe my ratio is leaner at idle to 5k; need to get on the Dyno.
Kawabonzai
Leader of the Back.
posted August 26, 2008 03:07 PM        Edited By: Kawabonzai on 26 Aug 2008 16:15
I think you mean that I am "rich" below 5k compared to the leaner readings above 5k.
My mod run is in red, the target line is I think 13.1
anything less than 13.1 is richer more towards a 1:1 ratio, and anything above is leaner towards 14.7:1.
Below 5500 rpm I was richer at 12.35 to 13.0.
After 5500 rpm I lean out to above 13.1 with a tiny dip in richness at 8200 rpm.
Am I reading that right? If not my cars are screwed up too, lol.
I loved all RPM ranges, it pulled hard all the way.
I wish I would have done my mods in stages, then I'd know what had the most impact on power.
I hear folks complaining about the Muzzy mapping, but I dyno's my bike a week apart and liked what I saw. My butt-dyno approved as well.
0.33618998527527 seconds processing time
