BIKELAND > FORUMS > ZX-14.com > Thread: shift indicator, indicating wrong gear? NEW TOPIC NEW POLL POST REPLY
pazx14rider
posted August 24, 2008 12:10 PM
Question for anyone with brocks system, pcIII, flies out. I was at the track on saturday missed my first shift so after leaving the track for the day just feeling everything out to make sure all was good because i have never missed a gear on my zx14 in 7000miles. I was watching the shift indicator and when i shifted from 4th to 5th it would show 6th momentarly then show a solid steady 5th. Doing this downshifting also in all gears except 1st and 2nd. anyone know if this is normal for having the secondaries out? maybe i never payed attention to it before? trannys workin good no problems observed shifter looks tight. appreciate the help thanx
street racer
posted August 24, 2008 12:56 PM        Edited By: street racer on 24 Aug 2008 13:58
its normal...there is a slight delay before it picks the right gear. Mine does it too and it shifts perfectly.
lietoome
posted August 24, 2008 01:09 PM
normal
xtro
posted August 24, 2008 09:00 PM
i had a speedohealer go bad i think ... still testing ...
now with stock speeds sometimes cause of my gearing it says 4th but normally 5th when I'm in 6th ... depends on speeds ect ... so I pull inthe clut h . sure nuff ... i'm in 6th .. might stay .. might not ..
Superman T
posted August 25, 2008 08:53 AM
normal
pazx14rider
posted August 25, 2008 03:51 PM
ok thanx guys minds at ease now, guess i never really looked at the indicator before
posted August 25, 2008 04:25 PM
i use a speedo healer -8% and somtimes my indicator changes a number lower after a shit
0.21404695510864 seconds processing time
