BIKELAND > FORUMS > ZX-14.com > Thread: Does anyone here weigh 225-230 have some suspension settings? NEW TOPIC NEW POLL POST REPLY
budwardo
posted August 15, 2008 06:36 AM        Edited By: budwardo on 15 Aug 2008 07:37
I just cant get the suspension dialed in on my 14 how I think it should be. I weigh about 225 naked and like to ride fairly hard in the twisties. The bike likes to wallow in the turns pretty good. Does anyone have some settings they suggest? What I mean by that is how many clicks, lines showing, ect. I know everyone is different just what to get some kind of baseline to start from. Thanks
nydhags
posted August 15, 2008 11:45 AM
I used the link below as a starting point and upped it a little from there.
http://www.zx14ninja.com/phpbb2/viewtopic.php?t=6550&postdays=0&postorder=asc&start=0
To Do List:
CONTINENTAL US DONE
Hawaii - I’ll rent a bike there, MAYBE
Old Guy
posted August 15, 2008 12:38 PM        Edited By: Old Guy on 15 Aug 2008 13:41
You need to get with a good suspension guy and put new springs on. I have a 06 with 15K miles and mine are toast. Even new there wasnt enuf spring for my 180 lbs on track days. I'm going with .95kg springs in front and valve work. Just a 2 valve Penske shock out back with a bit heavier than stock spring. i forgot what the rate was. If I didnt have atrack only bike I would go stiffer. But the 14 is gonna be mainly street now.
A big Cat like you needs at least 1kg springs in front. Search the web for motorcycle suspension and one of the major players has a spring calculator in its site. But I know these stockers are too light for a heavier dude who rides hard. 7.5 wt oil in the forks might help but thats just a bandaid not the revalve you probably need.
The link nydhags will get you started. Print it and keep notes on your adjustments. Currently both my rear valve adjustments are 1/2 turn open from bottomed and the front is at 3&5 clicks out.but as i said my stock stuff is toast from track days.
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
posted August 15, 2008 01:15 PM
+1
The ZX14 is known for soft shock
budwardo
posted August 15, 2008 01:23 PM
thanks for the input. I have had some 1000s before and I ride my 14 like them. I really like my 14, you have to "lean it like you mean it" to get her to really rail. I posted awhile back that I rode a 08 busa and was impressed with its handling. I think they come with a lot stiffer spring than the 14.
posted August 15, 2008 02:24 PM
Above the rear shock loosen the lock colar by turning it counter clockwise...
Get a permanent marker and mark one of the tabs, then turn the shock colar 3 full turns clock wise...Retighten the locking colar and go for a ride to see how it is...
0.2824649810791 seconds processing time
