BIKELAND > FORUMS > ZX-14.com > Thread: question for u guys NEW TOPIC NEW POLL POST REPLY
Smooth_G
posted August 14, 2008 05:02 PM
question for u guys
i read a thread that said the 06 had a 42tooth sprocket,, did the 06 14 have a 42 tooth rear sprocket,,or 41,,i am running 16/43,, but i am changing it back,,i think its alittle to low,,,i wander about 16/42,,probably not much difference though,,just acouple hundreth of a turn,,,
posted August 14, 2008 05:50 PM
stock 06 is 17/41
zx14mike
posted August 14, 2008 06:51 PM
I went from stock to 16/41 to 16/42 and i clearly noticed a difference with the one tooth going to a 42 rear........it wasnt a HUGE difference but it was clearly noticable.
Also for the record I think 16/42 or 17/45 are perfect ratios for the 14 good for street, strip, highway, in town and everything in between.
lietoome
posted August 14, 2008 09:05 PM
17/46
zx14mike
posted August 14, 2008 09:16 PM
Why you changing yours Jeff...........I thought you were a hard core 17/45 fan?
Smooth_G
posted August 14, 2008 11:15 PM
i think i am going to 16/42=2.63 until i need a new chain,,then i might go 17/45=2.65,,but bigger sprockets the chain dont turn as sharp, less friction
posted August 14, 2008 11:20 PM
Yup!
they last longer too!
madboost
posted August 15, 2008 07:43 AM
stock wheelbase depending on the weight, stick with stock 17/41 or go up one on the rear.
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
zx14mike
posted August 15, 2008 08:29 PM
WHY????????
kawboy81
Busa Eater
posted August 15, 2008 10:57 PM
I heard that going up on the rear and leaving the front alone makes it more wheelie prone?? Correct me if I'm wrong but there's a local stunter here that said the front is usually stock and they only go up in the rear. I don't know. I'm running 16/41 now and love it. 16/43 was to much for me as I do slot of highway riding as well.
07 LE bolt on bike
posted August 16, 2008 02:52 PM        Edited By: dubious on 16 Aug 2008 15:54
16 /41
if your getting a new chain, then 17/44 !
same gear ratio, but bigger circle equals less friction, and more teeth = more miles / life !
I am 210 suited, so bigger guys might want 1 -2 extra tooth on the back, depending on use.
Smooth_G
posted August 16, 2008 10:04 PM
more teeth more surface area to wear out,,lasts longer,,
flyboy
posted August 16, 2008 10:12 PM        Edited By: flyboy on 16 Aug 2008 23:14
http://www.gearingcommander.com/
This is the best gearing site I've found.
Plug is Kawasaki, Ninja, ZX-14 2006
"The World's Fastest Indian"
One fast red ZX-14,
Smooth_G
posted August 16, 2008 10:16 PM
flyboy,,i checked that out,,good site,,
lietoome
posted August 17, 2008 12:26 AM
Mike, I've honeslty forgotten what sprockets I've got on the bike now. Haven't ridin' in over 10 months.. I've got several combinations, I think I still have the 18t on the front from my road trip??? I even have the 40T that Halvesfast broke 200 mph with in Texas.
0.23303198814392 seconds processing time
