BIKELAND > FORUMS > ZX-14.com > Thread: Since We're on Clutches....... NEW TOPIC NEW POLL POST REPLY
ghostman
posted August 12, 2008 08:09 AM
I think it's about time to change my clutch fibers and steels. I've noticed in the last thousand miles that I have to have the clutch almost completely engaged before any grab.
What site can I go to that carries a complete OEM clutch pack?
I'm There Whether You See Me Or Not.
shane661
posted August 12, 2008 08:26 AM
http://secure.mycart.net/catalogs/catalog.asp?prodid=4818803&showprevnext=1
ghostman
posted August 12, 2008 08:29 AM        Edited By: ghostman on 12 Aug 2008 09:31
OK, dumb question. Is the Clutch cover gasket reusable?
Also should I replace the springs while I'm at it?
shane661
posted August 12, 2008 08:35 AM
I didn't try since I was installing a new billet cover....
ghostman
posted August 12, 2008 08:43 AM
Iz all good. I'll just order it to be safe.
posted August 12, 2008 09:05 AM
Just be carefull with the gasket, I have re-used mine at least 5 openings already!!!
Always good to have a new gasket available...
posted August 12, 2008 12:54 PM
schnitz racing has them
ghostman
posted August 12, 2008 01:35 PM
Good look fellas!!
Bently
2012 14r In Blue and no Mods!
posted August 12, 2008 01:58 PM
Gasket should be able to be reused plenty of times, but never hurts to have one on the shelf just in case!
billeason
posted August 12, 2008 03:19 PM
clutches
+ 1 If you have one on the shelf you'll probably never need it, Cheap insurance....Bill...
bill eason
Hurricane
posted August 12, 2008 03:31 PM
Why do the job twice! Replace it...
06redzx14
posted August 13, 2008 06:10 AM
what do you guys think about the brock springs and spacers? I'm looking to get a better feel from my clutch
madboost
posted August 13, 2008 11:22 AM
if youre heavier over 200lbs its a good idea to get brocks spacers and springs....guys swear by them
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
ghostman
posted August 18, 2008 09:53 AM
Can't remember; which side of steels go in facing the clutch master?
jdrill04
posted August 18, 2008 04:03 PM
the tapered side goes in flatside out.
NOX
PMRA / TMRC Super Street 4022
posted August 18, 2008 04:21 PM
If you are tuning a clutch at the track, you may have it off 5 times in one day........
Stock gaskets are great, I have "re used" one over 50 times
I like the cometic better......., if there is any place where it might seep, the cometic will stop it......
BUT, one thing I will say about Muzzys is, thier lock up spacer was a better finish than the MTC, and I could re use stock gaskets tons of times........, had to switch to cometic when I went with the mtc spacer........
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
posted August 18, 2008 05:52 PM
rounded edge goes into the bike. sharp side facing out so when you let the lever out theres no chance of the sharp edge catching on the hub and holding it out (making it slip continously).
BIKELAND > FORUMS > ZX-14.com > Thread: Since We\'re on Clutches....... NEW TOPIC NEW POLL POST REPLY
0.2412281036377 seconds processing time
