BIKELAND > FORUMS > ZX-14.com > Thread: First Clean Passes on the 14...Wow (Video) NEW TOPIC NEW POLL POST REPLY
posted August 08, 2008 04:59 PM        Edited By: Shane661 on 8 Aug 2008 18:05
I finally got the 14 back together and took it up to MIR. Racheal brought along her Gixxer as well. I got most of the teething issues squared, and the bike performed great all day. It needs fine tuning and some more setup, but it really impressed me today!
Before today, my personal best in the 1/4 mile was 9.96 on Racheal's bike. I had not been able to make a clean pass on the 14 yet. I suspected it might move my weight better than the 1000 (I am 230 pounds suited). Well, I was right!
I ended up running around 4 9.59's, and I had a string of runs (6, I think) all between 9.59 and 9.61. I also set a new personal best 1/8th, 330, and 60 foot. I was tired at the end of the day and having trouble hitting the 1-2 shift, but I ran two 1.52's.
Here is a 9.59 pass:
That is at 63.5" with +2 gearing.
I have a bit of setup and tuning to do. The data logger told me the bike was pretty rich up top, and I need to address that...among other things. But I couldn't be happier with the bike's first real runs!
PS. Not to be outdone, Racheal managed a 9.54 on her 1k....it's getting competitive around here!
smokinzx14
posted August 08, 2008 05:19 PM
Good numbers Shane ..More seat time and 9.30s are coming .. Add some cooler air 9.20s ....
posted August 08, 2008 06:32 PM
You didnt put a 16 tooth on the front yet???...9.59 not bad for a +2 in the rear!!!
See you on Sep. 5th...
zx14mike
posted August 08, 2008 07:19 PM
Good job Shane, btw, i'm curious how your numbers on the ZX 12 compared to the 14?
posted August 09, 2008 05:05 AM        Edited By: Shane661 on 9 Aug 2008 06:06
I can't really compare them fairly since the setup was so different. MPH was close to the same under similar conditions...but I haven't gotten the 14 mapped 100% yet. Also the 12 had velocity stacks and the engine was well broken in, unlike the 14.
I can say that the lower rpm grunt of the 14 is much more...but that is a given.
The 12 was running at stock wheelbase, -1 and +1 gearing. The 14 is at 63.5" with +2 gearing and I am about 30 lbs. lighter than last year. I had well over 100 1/4 mile passes on the 12, and I have about 20 on the 14. But it only took me 5 clean passes to get a 9.61 on the 14...it took me over a hundred to get 10.16 on the 12. The setups make it hard to compare.
Crotchrocket could give you a good comparison of the bikes, he has ridden both with similar setups.
tshultz
posted August 09, 2008 02:20 PM
Shane when you get the 14 dialed in is there going to be a grudge match between you and shiphteey?? Any way those are good numbers.
posted August 09, 2008 02:27 PM
We've been talking about some heads-up runs. I think he needs to get his bike dialed-in this year too. I think his best on the 12 is 9.40, and I'm sure he is looking to improve on that...
posted August 09, 2008 03:51 PM
man hes gonna be pissed when you beat 9.40 :P
shiphteey
posted August 11, 2008 07:57 AM
Meh, until I actually see a face shot with that video live in action, I don't believe its Shane!
Haha, good run man, you're getting the hang of it listening to the rpms as you let 1st out completely. We'll have to run before the season is over.
A.
Gemini Motorcycles
Superman T
posted August 11, 2008 09:29 AM
Shane- Good vid.....I haven't race on a track yet but look forward to the day I can go all out without having to think of the PoPo or some crazy pulling out in front of me. I've kept up with your mods and it's cool to see the final/simi-final product produce! Keep wacking the throttle and some of us will live vicariously thru you until the time comes.
0.27942609786987 seconds processing time
