BIKELAND > FORUMS > ZX-14.com > Thread: 08 zx 14 motor stalls NEW TOPIC NEW POLL POST REPLY
hardatit
posted August 08, 2008 12:24 PM
I have a 08 SE, I have muzzy m10 header and pipe, and a pclll with muzzy maps, lowered 1 1/2 inches in back 5/8 in front, brooks lower strap and components, heli bar risers. Any ways I was riding the other day and the bike just died while riding down the road. I tried to start it again and it would crank but wouldn't start. Got it home and messed with wires off the right hand side where the kill switch is and the bike started. So I proceeded to ride, a week later same thing happened messed with wires going to horn and it started. Finally I unhooked one wire to the horn and hasn't happened again. I don't know whether it is a short in the wiring, or something to do with pclll? The horn wire seems to get in a bind between the fork and fender. I could have pulled something loose putting my heli bar risers on. Has anyone had a issue like this? probable not.
ninjavin
posted August 08, 2008 12:38 PM
Check the ground wire for PC, a known problem where they have you place it. Wire it directly to the neg. side of the battery or at least a known good ground on the bike.
0.27415084838867 seconds processing time
