madboost
posted August 04, 2008 10:08 AM
MR9
what kind of gains are you guys seeing MPH wise in the 1/8th and 1/4 over 87 pump gas?
08 zx14-with a few things.
94z28 383,TH400,YSI,9",DFI and much more
9.44@144 w 1.5060ft
posted August 04, 2008 10:41 AM
3mph
johnnyrocketzx14
posted August 04, 2008 04:58 PM
well i tried it and didn't find any gain, but maybe my map wasn't what it could be or maybe my body can only travel so fast and no matter what i do i cant seem to get any change
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
ninjaboy311
posted August 04, 2008 05:19 PM
If you are running a Brock's map, you should have seen a change. Most of his maps are made for MR9 and U4.
Where did you get the MR9 from? Was it a fresh can? Was it ever kept in the heat? Possible that the O2 content of the fuel has released from the fuel, which will leave it running just like pump gas.
johnnyrocketzx14
posted August 04, 2008 05:40 PM
Edited By: johnnyrocketzx14 on 4 Aug 2008 18:40
called the VP man and ordered a can, it was new. That being said i don't think i have given it a fair chance. i plan to order another keep the air filter removed and make some more runs. its my understanding that is how the map was intended to be ran. it was a slight mix the last time i ran it with the new pipe, maybe almost 50/50 with the air filter in. All the other runs were with old pipe and custom made dyno map
07 ZX14
posted August 04, 2008 06:02 PM
Did you drain the pump gas out???
johnnyrocketzx14
posted August 04, 2008 06:07 PM
well i didn't remove the tank, i have a siphon hose and sucked it out then put the MR9 in. im sure it wasn't dry but way less than a gallon. then put 2+ gallons of the race fuel in. Was that bad?
07 ZX14
ninjaboy311
posted August 04, 2008 07:53 PM
Don't forget to drain it out after every day at the track. Leaves a gunky residue you don't want to experience.
02zx12rbob
posted August 05, 2008 12:18 AM
Giained 2-3 mph in the 1/8.
