BIKELAND > FORUMS > ZX-14.com > Thread: Cam Timing? NEW TOPIC NEW POLL POST REPLY
kimski2001
posted August 01, 2008 12:48 PM
Cam Timing?
does anyone have suggestions on Cam Timing on a 14?mods include,13.5to1 je's,head milled 10 thousandths,ported and polished,upgraded valve springs,manual timing advancer set @6.5 advance,smeg.will be putting it back together next week thought about 106/107 or 105 107 or maybe 105/105.i do alot of 1/4 mile stuff but mostly 2nd gear pulls.any thoughts is appreciated.
1st14injax
posted August 01, 2008 07:13 PM
the extra compression will allow you to advance the cams more for more top end, without hurting the midrange as much as stock compression.
If you like midrange power, leave the stock cam timing with the higher compression pistons for even more power in the mid!
I would not advance the timing that much with higher compression,and a milled head! ... PING! .... not that I know from experience on the 14, just other engines I have built, and I do know the stock compression with 4 degrees added runs it on the edge with pump fuel.
I also thought I heard that we only have 45 thous piston to valve clearnce stock, so I would be concerned about miulling the head and 13.5...
Just hearsay, I may be wrong,............. but better to be safe than sorry!
Hate to hear of any problems later for ya...
kimski2001
posted August 01, 2008 08:44 PM
Thanks dubious,im guessing my torque wont be affected down low?top end pulling power was fine with my stock motor.so yeah more midrange would be nice!
1st14injax
Smooth_G
posted August 01, 2008 10:36 PM
check piston to valve clearance during overlap
Cajunboyz
posted August 02, 2008 03:27 AM
Kimski2001, You have a PM
0.25435018539429 seconds processing time
