BIKELAND > FORUMS > ZX-14.com > Thread: need some more help please!!!! NEW TOPIC NEW POLL POST REPLY
wutbusa
posted July 18, 2008 12:20 PM
at the end of last summer i got ran off the road on my 14, and went in a ditch and hit a drain tile, this is explained in more detail in a post i put up last summer, anyways, i finally got new chrome wheels with new shinko stealth tires from and rear, new exhaust and a new radiator. i got it all back together sunday and heres my problem, the bike is trying to "tank slap" is what ive heard it called, the handlebars move back and forth and shake the bike horribly, basically its not safe to ride. it does it on accel but it does it really bad when you rev it out and let the motor hold it back and lightly hold the grips. any idea what it could be??? any ideas or help would be greatly appreciated, money was tight this year and i was so happy to get her goin again and now its chillin in the garage on a 90 degree day
jdzx14
posted July 18, 2008 12:27 PM
Im not an expert but sounds like a fork problem, maybe bent or something. And check the neck of the frame for damage i have seen them not break but fold up and crack. That would proly cause it.
2007 Black ZX-14
wutbusa
posted July 18, 2008 12:35 PM
i was thinking it was a fork problem as well, i did inspect the neck and didnt see any cracks, folds or pinches of any kind, kawasaki just sent me a recal notice on the frame last week, hopefully they will just replace it anyways, just didnt wanna take it in before i get to ride it a few times
davej
posted July 18, 2008 12:51 PM        Edited By: davej on 18 Jul 2008 15:10
Have always fixed tank slap with a new front tire. Had the problem real bad with stock tires, went to Michlin front and rear and now you can take your hands off any speed. Make sure your forks don"t have slop or a loose swing arm, bad bearings because of broken races.etc. With the new tires you have on, are they matched? Is your front wheel pointing in the same direction as the rear and are they parallel to each other? After an accident you can't rule anything out.
Triumph guy
Sticks_n_Stones
posted July 18, 2008 02:27 PM
Take your bike in to a dealer NOW. You either screwed up the tire n rim install, or have a alignment problem, or bent forks. Either way, they should be able to quickly (ie. cheaply) tell you whats wrong.
Could be as simple as having to unbind your forks at the triple clamps and reclamp them. (used that fix twice now on bikes that were in minor crashes and didnt ride right afterwards). Your life aint worth the $100-150 it will cost to have it looked over.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
Tool man
posted July 18, 2008 02:41 PM
+++1
The banks are failing..
The banks are failing...
Invest in Ammo
wutbusa
posted July 18, 2008 04:15 PM
i completely agree, ill call the dealer tomorrow and get it in there, thanks for the info and advice
Sticks_n_Stones
posted July 18, 2008 04:26 PM
No problem brother! Don't get me wrong, I'm a diehard backyard mechanic, too. But sometimes there is stuff that a certified mechanic in a well equiped shop needs to take care off if you want it done right.
'06 zx14
Muzzy M10/M14
PCIII w/ Muzzy map
Flies out K&N in!
bits n pieces...
AZ ZX14
posted July 18, 2008 07:04 PM
Keep us posted on your findings.
2008 ZX-14
Flies out
PCIII / USB
Brocks Alien head
Puig DB Screen
wutbusa
posted July 19, 2008 08:15 AM
will do for sure!!!
0.32309007644653 seconds processing time
