BIKELAND > FORUMS > ZX-14.com > Thread: speedo accuracy NEW TOPIC NEW POLL POST REPLY
Smooth_G
posted June 21, 2008 09:37 PM
speedo accuracy
i have 16 41 gearing,,i set the speedohealer to 13.8 %, with a new tire it was to slow,,i set it at 11% n it seems close,,i go by school that have those radar signs saying slow down,n it tells u your speed,,,the speedo is almost exactly that speed it say,,,we have letter streets,,ave H,,ave G n so on,,they r exactly one mile apart,, i check the odo n it is spot on,,with 16, 41 gearing what speed is 11000rpm in each gear,,,
fifth
The Magnificent Bastard
posted June 22, 2008 01:54 AM
1st - 77
2nd - 104
3rd - 131
4th - 152
5th - 176
6th - 196
you can check out different gearing combos for many different bikes at: http://www.gearingcommander.com/
Smooth_G
posted June 22, 2008 12:39 PM
THANX FIFTH,,,GOOD REFERRAL
reward69
posted June 22, 2008 05:34 PM
I have the same combo and have the healer set at 11.5% and is dead on. I have a good friend thats a trooper and he's clocked me at different speeds to verify.
fifth
posted June 22, 2008 07:25 PM
does anyone know how to set the speedohealer so that it removes the 186 mph limiter???
200hp_zx14
posted June 22, 2008 09:05 PM
I don't have the specifics but set it so there's a big precent of error. If you normally set it so there's 11% error than set it to 25% error. This way when your doing 180, the bike will think your doing 160 or so. Hence, by the time your bike thinks your doing 186mph, your actually closer to 200mph.
207HP* '06 Candy Blue ZX-14
Some mods done
Best run - 10.19@137.40mph
fifth
posted June 23, 2008 06:15 PM
Ditto
posted June 24, 2008 01:21 PM
i go -8% for stock gearing
fifth
posted July 07, 2008 05:54 PM
with those that have a speedohealer and 16/43 gearing, what is your speedohealer set to??
NCZX14
posted July 07, 2008 08:07 PM        Edited By: NCZX14 on 7 Jul 2008 21:11
I want to say mine is on -14.8% I'll double check tommorow that is based off of GPS constant speed. I'm using a Speedohealer V4. If you go on http://www.healtech-electronics.com click on the Speedohealer link, then to online calculator they have a estimate calculator based on gearing changes and tire changes that's is withing .2% of the actual GPS over indicated speeds I've calculated on it.
2K7 everything possible without going in the engine.
BobC
posted July 07, 2008 10:58 PM
At the track I use the "convert kilometers to miles per hour" setting. It gives massive headroom to avoid the ecu limiter and you can still read mph off the inner kph scale.
On the road I leave it in transparent as I run 17/40 gearing which is quite accurate on the speedo without any correction.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
0.25457906723022 seconds processing time
