BIKELAND > FORUMS > ZX-14.com > Thread: speed limiter NEW TOPIC NEW POLL POST REPLY
zx6reaker
D&D's, Frame sliders, pcIII
posted June 19, 2008 05:49 PM
speed limiter
I've heard of a chip of some sort that can bypass the speed limiter...does anyone have any info on this...anything at all?
Loud pipes and bright lights save lives.
Peno
Peno
posted June 19, 2008 06:06 PM
healer
speedohealer.com
lowcel
Happy on 2 wheels.
posted June 20, 2008 04:48 AM        Edited By: lowcel on 20 Jun 2008 05:49
Yep, it's the speedohealer. All you have to do is flip a few pin switches and you will be on your way. It takes less than an hour to install. As an added bonus it will correct you speedometer so you actually know how fast you are going.
2007 Z14 SE - Yoshimura TRC full race exhaust w/ carbon can - PCiii w/ map from HPC - Flies removed - Pipercross air filter - Speedohealer - Puig Double Bubble - Fender Eliminator - GPR Steering Damper - Puig Frame Sliders - HID's - Halo's
KikonZX14
Novice
posted June 20, 2008 10:19 AM
Hi lowcel, a question for you. I see that you have PCIII/Map/Flies out, and also have a Speedohealer........why? isn't PCIII+Map+Flies out enough?
Thanks in advance & Regards,
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
02zx12rbob
posted June 20, 2008 03:48 PM
Speedohealer fixes a couple factory problems.. 1-speed limiter 2-speedo accuracy.
lowcel
Happy on 2 wheels.
posted June 20, 2008 04:39 PM
David
Without the Speedohealer I still wouldn't know how fast I am going. I would also show more miles on my odometer than I really have, my mpg would not be accurate either. On top of that I have a cool little button that allows me to push it and see my top speed since the last time I reset it. With that button I can even see how fast someone drove it while I had it in for service.
The speedohealer does a job that the pciii can't do. It doesn't add any power to the bike.
Here it is from a little ride I did with my brother a couple of weeks ago.
0.25649690628052 seconds processing time
