BIKELAND > FORUMS > ZX-14.com > Thread: First time to dragstrip in 23 years NEW TOPIC NEW POLL POST REPLY
mokaw
posted June 15, 2008 06:36 AM        Edited By: mokaw on 15 Jun 2008 07:41
I have to say I was very disappointed in myself. Here's what I have:
06 14, Brock's smeg with track map in p/c, BMC race filter, Muzzy air shifter, M/T slcik, wheelie bars, 16/43 gearing and I weigh between 145 and 150.
I made 6 runs. There was also an ugly 20 mph headwind, too. Here's the best I did:
60 ft - 1.55
1/8 - 6.19 @ 116.44 mph
1/4 - 9.68 @ 137.82 mph
I haven't dragraced since 1983. I had butterflies in my stomach, didn't know if I'd do a burnout ok, didn't know if the airshifter would work right. In other words, I was nervous.
The air shifter worked great and I did have a blast. After 6 runs, my tailbone hurt so bad from the fiberglass seat I got from Schnitz, I figured that was enough. I have to get some padding for the back of that thing. My tailbone starting hurting on the 3rd pass. I couldn't concentrate on what I was doing. I'd take off and say "wow, that really hurts". Anyway, it's worse today. So much for that.
I think I need a little more gearing. I was launching at 7500-8000 and it would bog. I was still in 4th at the end of the 1/4. The M/T slick is about 1 inch taller than the stock tire. I think I might need a 44 or 45 rear. Any suggestions?
I just love that Muzzy air shifter. Didn't miss a beat.
Overall, I really enjoyed running down that strip again. I just wish I would've done better. Maybe next time.
Every knee shall bow, every tongue confess that Jesus is Lord!
posted June 15, 2008 07:55 AM
are you kidding, you did great! as someone famous once said, more seat time....
H0mr
posted June 15, 2008 08:50 AM
Dealing with a 20 mph headwind, unless it was at your back, you had some fun and your bike'srunning good!
2008 SE, Muzzy's M14, PCIII, Adj. lowering links, Heli risers.
BlackMagic14
posted June 15, 2008 08:52 AM
In the immortal words of someone else famous THERE IS ALWAYS BOOST!!!!!!!!!!!
nah you did great! it will come
kawasakijockey
posted June 15, 2008 09:05 AM
you really need more gear because with 16-43 and that 60 ft time, it should be at the upper part of 5th with a speed of at least 145mph with a stock height tire. I would think at least a 45 or 46 rear.
2007 ZX-14
1.38 60ft
9.03 @ 149mph
8.95 @153 small shot n2o
8.68 @160mph 5lbs boost
ZREXER
posted June 15, 2008 02:41 PM
Any time you are cracking 10's or less, it is not shabby at all! With a 20 mph head win and being your first time out in a long time, hat's off to you!
mokaw
posted June 15, 2008 02:51 PM
Thanks guys. I was going against a strong headwind but I also thought the mph should've been in the 140's. There was a guy there with a turbo busa and he said I need a 50 rear. I think that's way too steep. 44, 45, or 46? I'm open to suggestions. I'd like to get this right.
(Thanks kawasakijockey).
posted June 15, 2008 05:25 PM
Take that wheelie bar off and slide the clutch...Then your tailbone wont hurt anymore
mokaw
posted June 15, 2008 06:48 PM
You wouldn't believe how it hurts today! I need the seat because I'm short and I can get both feet on the ground with this seat. I just have to come up with some kind of padding for the back part of the seat where it curves upward.
0.48741602897644 seconds processing time
