BIKELAND > FORUMS > ZX-14.com > Thread: lowering the forks 1 " NEW TOPIC NEW POLL POST REPLY
jetskidave
posted May 20, 2008 10:49 PM
I also have a Yoshimura pipe and power commander with a custom map.
40 tooth rear sprocket...........1 down.
Tonight I lowered the from forks 1". Adusted headlight and tightened up the rear
suspenstion...........................anything else I can do to prevent 1st gear wheelies?
Thanks guys for all you help!
jetskidave
2014 ZX14R Flat Black
Akrapovic 4 into 1 exhaust CNC Performance high performance street motor stock bore 14 to 1 CP pistons
CNC ported head, Cams, 48mm Bored throttle bodies, complete blueprinted engine,
10 Over Adams arm, GPR stabilizer, air shifter, quickshifter Guhl reflash ECU with duel maps installed in the ECU.
243hp, 302 hp on Nitrous progessive controller. BST carbon rims
  Ignore this member    Click here to visit jetskidave's homepage.
ZXLNT
posted May 20, 2008 11:52 PM
Lower the rear suspension..
H0mr
posted May 21, 2008 12:19 AM
What about a wheelie bar? Years ago, I knew a guy who rode one on the street. Always wondered how it did when you were leaning in the corners though.
2008 SE, Muzzy's M14, PCIII, Adj. lowering links, Heli risers.
TATER
Shakin off the Haters
posted May 21, 2008 05:38 AM        Edited By: TATER on 21 May 2008 06:40
I put swing arm extensions on my 14 , And also installed a pair of lowering links.They work great. I prefer to keep the front end on the ground.
ZX-14 06
Flies out
-1 front, +2 rear
2 Bros carbon fiber pipes
Tiger tail
Carbon fiber windscreen
64inch wheel base
lowering links
RC components wheels
BobC
posted May 21, 2008 05:48 AM
Hi Dave,
I have a similar set-up to yours, I'm running a 40 tooth on the rear and stock wheelbase. The difference is I have Muzzy 3-position links on the rear, set at 3 inches lower, the front lowered 1 centimeter and strapped too and I have had no problems with 1st gear wheelies. Did a 9.84 sec quarter the other weekend with a 142 mph terminal.
I think you need to lower the rear and strap the front to get the best from the bike. If you use a swing arm extension then you will be having grip problems instead. It's a trade-off. How non-standard do you want to go and do you still want to use it on the street?
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
bulldogprostock
posted May 21, 2008 05:53 PM
+1 to Tater and BobC
You don't want to lower the front without lowering the rear. The reason being that lowering the front will decrease rake and trail. Although this will increase steering response and side to side transition speed it will also sacrifice straight line stabilty. This could result in headshake and since the ZX14 doesn't have a steering damper you may find yourself on the pavement in the blink of an eye. One more thing, the front of the ZX is lightly sprung to begin with and you may want to add spring preload and compression to the help keep the front wheel from possibly getting into the radiator.
2001 Busa, 2008 ZX14R, K6 GSX1000R
ninja14
posted May 21, 2008 05:56 PM
1" .......hope you don't plan to make any turns - the pegs and fairing will be dragging.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
posted May 21, 2008 07:38 PM
+1
TATER
posted May 22, 2008 08:13 AM
Well I only droped the forks about 3/4 of a inch and the lowering links is set in the middle whole, I had it on the lowest hole, but i dragged my head pipe in a turn , so that why its on the middle hole.
ZX-14 06
Flies out
-1 front, +2 rear
Tiger tail
64inch wheel base
lowering links
BobC
posted May 22, 2008 08:28 AM
On the lowest hole there's also a risk of the rear tire rubbing on the undertray.
Stock wheelbase
BIKELAND > FORUMS > ZX-14.com > Thread: lowering the forks 1 \" NEW TOPIC NEW POLL POST REPLY
0.44546604156494 seconds processing time
