BIKELAND > FORUMS > ZX-14.com > Thread: WOT switch mounting??? NEW TOPIC NEW POLL POST REPLY
jdzx14
posted May 20, 2008 09:42 AM
Can someone post a pic of the best way to mount a WOT switch on a 14? Thanks in advance.
2007 Black ZX-14
smokinzx14
posted May 20, 2008 10:18 AM
cnote
posted May 20, 2008 12:08 PM
What is a WOT switch
jdrill04
posted May 20, 2008 12:21 PM
wide open throttle switch. it activates the nitrous when your throttle is wide open.
TH1RT3EN
Trial And Error Control
posted October 28, 2010 03:19 AM
Does anyone have another pic of how to mount one of these switches? I am not running Nitrous but am thinking about trying something else....
Patrick
posted October 28, 2010 06:26 AM
TH1RT3EN
posted October 28, 2010 07:04 AM
Sweet! Thank you Sir!!
TH1RT3EN
posted October 28, 2010 10:24 AM
Should these switches always be hooked up with the negative?
(i should not run power through it correct? if i were to run power through it, it would be a very low current draw and low amp draw. maybe .3amps and 8V draw)
Patrick
TH1RT3EN
posted October 28, 2010 05:17 PM
here is another use for the WOT switch. This was mentioned to me by a board member here. Since i am not a full time drag racer i have a lot of things to work on. Getting to WOT fast and consistently is one of my issues. So i used the switch for this...
Anything Under WOT
WOT
Patrick
0.36521697044373 seconds processing time
