BIKELAND > FORUMS > ZX-14.com > Thread: Speedo Healer installed ( surging problem now) NEW TOPIC NEW POLL POST REPLY
northmedic
posted May 19, 2008 01:02 PM
So after getting the new V4 speedo healer and using it for 2 days my bike started to surg in 5 gear around 4 to 7 grand , The first few days the speedo healer only showed 5 in 6th gear which it suppose to . now it does the same in 5 gear it shows 4 , thats when the surging started , talked to speedo healer they recomended i set my correction less . or to put the gtre on instead , anyone else have this problem and get a fix ????
I,ll be right back
BobC
posted May 20, 2008 02:53 AM
To be honest I run my Speedo Healer in transparent mode for the road and set it to "convert kph to mph" for the track. At the track it's never on part throttle, just open or closed. I have ridden it down to the shop a couple of times set for the track and didn't notice anything unusual. Can we assume you have the secondary butterfly's removed? If not that could be the cause.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
lietoome
posted May 20, 2008 03:55 AM
is your idle rpm correct? thinking out loud...
cajunboyz
posted May 20, 2008 04:10 AM
I think if you convert kph to mph that that would allow you to run way pass the 200 mark, the speed restictor would be waay up farther & the speed restrictor would NEVER be hit ???
Is this correct BobC ????
BobC
posted May 20, 2008 04:20 AM        Edited By: BobC on 20 May 2008 05:21
Absolutely right, that's why I use that mode. It also allows you to read mph straight off the inner kph scale as a bonus, giving you a 300mph speedo.
Stock wheelbase
cajunboyz
posted May 20, 2008 05:21 AM
& once converted from kph to mph , you can set it where your inner(kph) reads correct in mph??? & the speed restrictor is still waaay up there??
northmedic
posted May 20, 2008 11:09 AM        Edited By: northmedic on 20 May 2008 12:11
THanks for the replys gang
My bike currently flys out pc3usb brocks sidewinder baffle in map , muzzy duel airshifter/nitrous, nos not installed 16/43 gearing , since i installed the V4 speedo healer 2 days of use it started to surg in 5 gear but only when it drops to 4 indicated and does not always do this . what i have noticed if i recall my top speed before each ride the speedo healer only when in 6 show 5 gear if i do not recall the top speed it then also show a incorrect gear in 5 , this has been only trialed today and will keep a close eye on it , the Fix from Speedo healer was my money back , get a Gpro tre unit or cut a wire on the ecu, they stated that some zx14 have been reported to having the surging problem but they where unable to duplcate it on the zzr14. ( yes idle is set at 1100 or so)
I,ll be right back
BlackMagic14
posted May 20, 2008 06:44 PM
Does the V4 have a long cord with a little red button on the end of it?? I had on installed when it was in the shop and I just saw this cord the other day and was curious what the hell it was..
northmedic
posted May 20, 2008 08:31 PM
That Cord is your recall button to see what your last top speed was
I,ll be right back
ninja14
posted May 21, 2008 05:15 PM
The 16/43 gearing is why the display is wrong - mine goes 1/2/3/3/4/5
If you have not set the throttle position in the PC is could be part of the problem.......better not cut any ECU wires b/c they carry multiple signals.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
blackbullet76
posted May 22, 2008 04:56 AM
I've been running my speedohealer for quite a while now and i've never experienced the gear indicator problem that everyone else has. Guess I'm lucky.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
ninja14
posted May 22, 2008 10:41 PM
You don't have enough gearing for it to present..............stick a 43 on the back and look again
2006 Turbo ZX-14.
northmedic
posted May 23, 2008 07:05 PM
so after a fellow board member mentioned zeroing my throttle positon / and i put my speedo healer to a -14.9% correction the surging has left for now , thanks guys
I,ll be right back
ninja14
posted May 23, 2008 07:41 PM
Glad SOMEBODY could help
2006 Turbo ZX-14.
0.23799991607666 seconds processing time
