mcair
posted May 08, 2008 05:58 PM
Radar Detector mounts - safest?
My first mod, and most critical in my mind, is the installation of a radar detector. I got a nice Bel RX65 and Techmount. Wondering whether the velcro supplied with the techmount is solid enough to keep the $300 detector in place when going over bumps etc. Any recommendations for a more solid/permanent mounting?
Also, I'm planning to wire the detector directly to the battery - is this better/worse than trying to figure out how to plumb it into the electrical system?
08 ZX14 Atomic Silver
07 ZZR600 Red
92 ZX11 Black/Purple / 86 Ninja 1000R Red
79 GS850 Black / 77 CB250 Orange / 76 FS1E Burnt Red
Live like a Republican - vote Democrat
Lacker 14
posted May 08, 2008 06:07 PM
Try ram mounts.That what I use for My Valentine V-1.Good Luck
posted May 08, 2008 07:51 PM
I found the widscreen the best....
I bought a spare winshield mount , the standard one with suction cups for the RX65, drilled 2 holes in the windcreen, removed the cups and bolted the mount up with button head bolts.
Later I swapped to black bolts on the tinted screen... hardley even noticable
Works great.
posted May 08, 2008 07:55 PM
Also, I used the marker lamp wires, for power outlet. The marker lamps are always powered when the igniton is on.
I put a powered outlet in the ram air cover.
Saved my hide many times !
zx12mark
posted May 08, 2008 09:27 PM
Edited By: zx12mark on 8 May 2008 22:28
i did it this way. it takes a little longer.....well o.k. a couple of days but it`s the ultimate.
mcair
posted May 09, 2008 02:57 AM
@Dubious: you trust that stock Bel mount? I was testing the detector in the car with it and a) the bracket barely has enough heft to support the detector and b) the slot-in design is crap. I made a slightly-heavier than normal stop and the detector ended up in the passenger seat. I'm getting a zero-gravity windscreen and don't mind the drilling, but I can't see the detector staying on that clip if I made a sudden stop.
I do like the 12v outlet, way cool.
07 ZZR600 Red
posted May 09, 2008 07:16 AM
The only problem I have ever had with the stock bracket is the suction cups.
The detetor has naver come out of the bracket, I have used it for 3 years and over 100,000 km or 60,000 miles combined, in car, truck and on bike.
As long as you make sure the positive stop is locked and the detecor levers itself ahainst the windscreen is will never come off, unless the windscreen does.
Once you have the detector in the bracket, give it a little pull , as if trying to remove it without depressing the latch button. This ensures it is locked in. I used 2 little rubber bumpers on the detector , designed for kitchen cabinets so as not to scratch the windscreen or windshield, plus they dampen some of the vibration, and actually grab the the surface its levered against.
Unless you live in Russia, I can almost guarentee, your roads are in better shape than ours.
also this is in the mail for me....
http://www.legalspeeding.com/HARD.htm
the 12 volt outlet is good for electric vests, gps or whatever else too.
Marks got the hot setup, but I spent $5000 on turbo instead of $3000 on radar/lidar detection...
ekz
ed
posted May 09, 2008 07:51 AM
i have the techmount on my bike and also use a black zip tie because I do not trust the velcro as the only thing holding on the device.
mcair
posted May 09, 2008 09:00 AM
So that's what the button in the middle does. Maybe I should look at the manual sometime.
Thanks!
07 ZZR600 Red
KikonZX14
Novice
posted May 09, 2008 10:14 AM
Lyle, wich is the manufacturer of you smoked windscreen? I just got a Pit-Ek.
Hugz
David
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
posted May 09, 2008 10:56 AM
Edited By: dubious on 9 May 2008 11:57
The one pictured is a PUIG dbl bubble.
I am putting a Zero Gravity standard smoked one on it though...
I found the double bubble shot the wind at the top of my head, and like the flow dynaics of the standard height better,
mcair
posted May 09, 2008 03:35 PM
Done. Hooked up to the position lamp per Dubious, reinforced velcro to Techmount per Ekz. Thanks guys I'm good to go.
07 ZZR600 Red
fury
posted May 09, 2008 04:54 PM
Anyone have a site for reasonable priced radar detectors?
fury
posted May 09, 2008 04:56 PM
Edited By: fury on 9 May 2008 17:57
quote: i did it this way. it takes a little longer.....well o.k. a couple of days but it`s the ultimate.
Can you explain to me what is in here.
Thanks!
mcair
posted May 09, 2008 06:22 PM
quote: Anyone have a site for reasonable priced radar detectors?
I paid $260 for the Bel RX65 on Ebay. According to Radar Roy and others it is the best, and I need it coz I just got a 3-pointer in a construction zone. Or there's Cobra's at Radio Shack and elsewhere for $30 bucks that include laser detection. Who knows? As long as it keeps you one step ahead of the Federales...
07 ZZR600 Red
zx12mark
posted May 09, 2008 07:57 PM
zx12mark
posted May 09, 2008 08:01 PM
move mouse arrow over above pic.
mooniac
posted May 10, 2008 04:05 AM
Edited By: mooniac on 10 May 2008 05:06
Bell sells an external speaker that fits under the front side black plastic. Plugs into the bell jack outlet. It is really loud! Not 150mph loud but I can hear it @ 100mph or less with a full helmet on. I think bell sells it for around $30.00. Highly recommended.
07 R1, 07 FJR, 07 ZX14
(soon),
F1 ROCKET(300 HP Home
built Airplane) And it is faster
then your ZX14!!! (alot)
posted May 10, 2008 08:05 AM
quote: My first mod, and most critical in my mind, is the installation of a radar detector. I got a nice Bel RX65 and Techmount. Wondering whether the velcro supplied with the techmount is solid enough to keep the $300 detector in place when going over bumps etc. Any recommendations for a more solid/permanent mounting?
read the mount review in the article's archive... velcro is more than enough to hold the RX65 to the techmount... I run that exact setup and have tens of thousands of miles on it.
tell them you're a bikeland member when you call..
oh... ram mounts=junk.
re: hooking up to the battery, this is also in the radar review in the articles section (links in menu bar above) ... have mine hooked into battery directly as well with no probs
hope this helps
princesskiwi
MISTRESS of SMACK
posted May 10, 2008 08:09 AM
http://www.bikeland.org/story.php?storyID=18827
The dose differentiates a poison and a remedy....
posted May 10, 2008 09:48 AM
i use a techmount for the power commander lcd and it holds solid with velcro at extreme speeds +1 for techmount
fury
posted May 11, 2008 08:45 AM
Thank you!
Nice!
