BIKELAND > FORUMS > ZX-14.com > Thread: Need GPS USB to bike adaptor NEW TOPIC NEW POLL POST REPLY
Ranast
posted May 08, 2008 02:22 PM
Sorry if this seems like a silly question (I don't know much about wiring or electrical work).
I have a Garmin Nuvi 200 and a good mount for it. The GPS has a stated 4 hour battery life, but that isn't long enough for all rides. I need an adaptor to hook up to the bikes battery for the GPS. I know there must be products out there for a simple hook up but I can't find them.
The connector must have a small USB connector to go to the GPS.
Any help?
posted May 08, 2008 02:55 PM
Why not splice the GPC cigarette lighter cord into 12V at the front of the bike
Ranast
posted May 08, 2008 03:07 PM
Honestly I am not comfortable cutting and splicing on my bike. I have done it installing a car stereo but it was quite a ghetto setup (did it in my teens). I would prefer not cutting into the wiring if possible.
KawaBonzai
Leader of the Back.
posted May 08, 2008 03:57 PM
If you splice in the wrong spot you will be missing the voltage drop circuitry from 12v to 4.5v. then your GPS will go poof.
I've seen folks go to Pep-Boys or such and get a cigarette lighter extension.
Cut the one end off and wire that to the battery.
Then you can plug any device which has a cig charger cord into the remote cig receiver.
Kind of like a accessory port, but hidden under the cowl.
... Bonzai
2009 ZX-14 Candy Lime Green
posted May 08, 2008 04:00 PM
its simple top splice into the 12 volts anywhere up front. Kawa, always check for voltage on a wire before using the wire, thats what multimeters are all about.
I guess the cigarette lighter plug to the battery is a good idea if you're worried about a splice, but i must strongly suggest you put a fuse inline too if you go that route.
derpie
Dont judge a book by its cover
posted May 08, 2008 04:17 PM
Or if you have a battery tender setup, you can just get another wire for it and splice .That into a cigarette lighter plug and plug that in before you roll out, and they come with the fuses built in already. just my two cents
0.21844387054443 seconds processing time
