BIKELAND > FORUMS > ZX-14.com > Thread: whats some of the best sprocket combo's NEW TOPIC NEW POLL POST REPLY
bayou boy
posted May 08, 2008 05:20 AM
i see most folks go 1down in front,2 up in tha back.(16-43) an how does that compare to 17/44 gearing...
does wght play a factor, or u gear by ur wght to get most out of ur bike.
BobC
posted May 08, 2008 05:37 AM
There's no definitive answer to that, it depends on whether you want top speed or acceleration and on wheelbase.
Stock wheelbase
Max: 205.4 mph in 1.25 miles
Brock CT Full System. etc
Max: 203.1 in 1 mile (so far)
NOX
PMRA / TMRC Super Street 4022
posted May 08, 2008 05:38 AM
17 44 is a higher ratio than 16 43
divide little number into big number.........
front into back, and that will tell you.........
You gear for your bike, not what someone else is running. Some go for top of 5th some top of 6th............
42 Wins
21 Runner-ups
Sponsored by:
Scorpion Helmets
Galfer Braking
AMSOIL
Steve's Speed Shop
Kawasaki Sports Center
Mickey Thompson Tires
Catalyst Racing Composites
Conway Cycle
Syed Leathers
zx14mike
posted May 08, 2008 06:31 AM
In general you gear for your weight and riding style and preferences...........i would also look at how much time you spend on the highway, the strip and stop and go in town.
As for the ratios, 16/43 is 2.69, while 17/44 is 2.58..............only thing is, you will need a new chain to go 17/44, while you can go 16/41. 16/42 or 16/43 with a stock chain.
posted May 08, 2008 08:25 AM
stock is fine for me, if you are drag racing gear it down, salt flats gear it up, can't decide leave it alone
bayou boy
posted May 09, 2008 06:41 AM
thanks,
lietoome
posted May 09, 2008 07:09 AM
17/45
posted May 09, 2008 07:24 AM
I like a frt sproket with larger radius, and more teeth, the bigger the circle the more efficient it is. Also, they last longer....chain and sprokets.
lietoome
posted May 09, 2008 02:03 PM
+1
butterthegreat
posted May 09, 2008 03:34 PM
So since I am commuting....should I go 18 41 for mileage?
zx14mike
posted May 09, 2008 09:30 PM
Is most of your commuting on the highway or stop and go in town?
Also how do you feel about the stock gearing, and what is your riding style, would you like longer more mellow gears and lower RPM highway cruising or do you like shorter snapier gears and more acceleration.
If your commute is mostly stop and go in town or 70 MPH or less, like Dubious sated on a previous thread, you might not see any mileage increase or might actually see decreased milage and decreased clitch life if you go to higher gearing..............now if most of your riding is 90-120mph highway cruising then you will very likely see increased mileage from going to an 18/41 or similar ratio.
Keep in mind gearing is a compromise and you would be giving up some acceleration and lowend snap for lower RPM high speed cruising.
zx14mike
posted May 09, 2008 09:33 PM
Dubious, sorry to hijack the thread, but did you say on a previous thread you are an oil/energy consultant in Alberta?.......................if so would you mind if I PM'd you and picked your brain with a few quick questions???
lietoome
posted May 10, 2008 01:18 AM
commute with the stock gearing.
posted May 10, 2008 10:26 AM
stock gearing feels plenty tall to me
zx14mike
posted May 10, 2008 12:41 PM
+1
zx14mike
posted May 10, 2008 12:48 PM
For the 14, I REALLY like ratios between about 2.60 and 2.66
Here's a list of some key ratios:
18/41=2.28
18/42=2.33
17/40=2.35
17/41= 2.41
17/42=2.47
17/43=2.52
16/41=2.56
17/44=2.59
18/47=2.61
16/42=2.63
17/45=2.65
18/48=2.67
16/43=2.69
17/46=2.71
MJ
posted May 11, 2008 02:24 AM
Yep you could easily go down a couple teeth in back with no problems. I wouldn't go up in gearing at all. Leave it stock for highway/commuting, drop it some if you're wanting more giddy-up-go. Mines a beast with stock gearing..I personally wouldn't want it too much lower. Its faster than hell now, wheelies and lights the rear on demand, and still makes an awesome highway bike.
bayou boy
posted May 11, 2008 06:24 AM
thanks, it's just for the track, right now i'm 17-44, still got plenty of top end for 1/4, i 'm also 215lb's 6'2. most riders are always mostly smaller then me, sixty foot 1.55 last time at track,have did better in past, tryin to see if i change my sprocket would that help any , an still keep a decent top end.
ninja12
posted May 11, 2008 07:31 AM
bayou,
What is your mph in the 1/8 and 1/4?
I'm same weight and seeing 117 and 142 mph, running 16-43
zx14mike
posted May 11, 2008 08:02 AM
Bayou and Ninja, what gear are you guys in when you cross the line...............my guess is that with 17/44 it would be 4th gear and 16/43 it would be 5th gear...........i'm assuming the extra shift would cost time and wondering if it would cost MPH as well?
butterthegreat
posted May 11, 2008 08:32 AM
Most of my commuting is highway....90+ most of the time. I average 40 mpg...just wondering if I could pinch 1-2mpg out of the bike.
zx14mike
posted May 11, 2008 08:39 AM
if thats what your looking for it could possibly be worthwhile............18/41 would probably drop the RPM 400-600 rpm at 90 +
blackbullet76
posted May 11, 2008 06:02 PM
At the track I use 16/44. Street is 16/41. Does good for me.
2007 ZX-14 black
Brocks s-meg exhaust
PCIII w/track map
BMC race filter
Flies removed
16 tooth front sprocket
Speedohealer
APE cam chain tensioner
Vortex rearsets
bayou boy
posted May 12, 2008 05:58 AM
i 'm in louisana, but go to miss track a few times..
the weather is different down here, cause i see times posted on here from folks up north they doing 140 something runing low 9"s, 150 something runing high 8's.. down here in louisana, we run good mph, but our times an't like that, i ran 156 got low 9's, i 've ran 161 got high 8's..
my bike the way it's set up, i had a 65 shot set up in it, last i did tha 8was 123 i think, ran a decent time.,
now i have a 80 shot of wet, i should stay in the 8"s, but i want to run my bike up north.
even the horse power is different down here, i pull 173 with pipe an pc,brock smeg, then i added cams,pistions,head work, i pulled only 195 on motor plus 65 shot which netted me only 48 true horses so that's 233 hp, wilburn dyno's my bike, one thing i will say, my bike performs well when it lv's wilburn, i never under stood how guys where pulling more then me,with way less work, then my man said that guys where geting dyno but it was not corrected of something, a different switch. then he showed me my bike on that mode , it was crazy numbers, i felt better...so for big guys ,i just try to build my bike to match my wght, cause lil guys an't bullshitin....i 'll be at hattisburg this weeken, an i 'll keep my timeslip an show u....i have to email it to u, cause i can't post pic's up here.
my email is shortyline@yahoo.com i talk more in detail about my bike to u, an ur's see if we can come up with something just to see if we can do better.
ninja12
posted May 12, 2008 06:49 AM
Crossing in 5th , brock pipe and map , approx 4-5 over with bolt-ons, and 16-43 gears.
210 lbs before leathers. shifting at redline.
BIKELAND > FORUMS > ZX-14.com > Thread: whats some of the best sprocket combo\'s NEW TOPIC NEW POLL POST REPLY
0.39832401275635 seconds processing time
