BIKELAND > FORUMS > ZX-14.com > Thread: ZX-14 slighty surging @ Idle? NEW TOPIC NEW POLL POST REPLY
Cajunboyz
posted April 25, 2008 03:50 PM
My 14 starts fine, & after its warmed up , At idle its slightly surging ,like its hunting. When you ride it & come down to a stop idling it still slightly surging?? Anything I can look towards?
smokinzx14
posted April 25, 2008 03:58 PM
What is you idle speed ? What map are you running ? Did you set the throttle setting in your P/C ?
Cajunboyz
posted April 25, 2008 04:12 PM
Idle speed @ 1500rpms slightly surging. yes the throttle positon shows 0 & i had set it last year. Its been so long that i set it, I forgot how to go over it again??
smokinzx14
posted April 25, 2008 04:20 PM
Idle speed should be 1000 to 11000 .... 1500 is a little to high ..... Try setting it lower and see what it does .. Dyno jet has the info on setting 0% and 100% on there web site .... You should reload your map and check throttle settings everytime you change your oil ....Just think of it as an oil change and tune up ...
Cajunboyz
posted April 25, 2008 04:38 PM
I did just reload the map. I'll eventually figure whats going on, I appreciate your suggestions & will look into th TP setting, but it was on 0. Thanks
FASTESTbusaAROUND
I eat Fish...
posted April 25, 2008 05:39 PM        Edited By: FASTESTbusaAROUND on 25 Apr 2008 18:40
If you've pulled the flies and done an exhaust, slight surging is normal in the very low ranges in 1st; even my Busa's did that. This is quite characteristic of the big bores...given all that low end TQ
FYYFF!!!
Bawls
re-learning to ride
posted April 25, 2008 06:47 PM
People are going to think you've got a blower . It's always fun to see the look on a person's face the first time that they go to lake Havasu AZ and hear all the boats surging.
Best 60ft: 1.42
Best 1/8th: 5.97
Best 1/8th MPH: 119
Brockland Police Badge # 001
Cajunboyz
posted April 26, 2008 01:10 AM
But the problem is I don't have a blower. Your right, Locally i have a few friends with Fountains with blowers. One thing is they will pin you back when you lay the "Hammer Down"
posted April 26, 2008 09:48 AM
lower you idle to 1000, you are not staging
0.21264696121216 seconds processing time
