BIKELAND > FORUMS > ZX-14.com > Thread: My ZX-14 Seat is Stuck on the Bike NEW TOPIC NEW POLL POST REPLY
SV1RIDER
posted April 23, 2008 11:04 AM
I have a 2006 ZX-14 and I tried to remove the seat the other day and it would not come off. I have had it off a few times before and had no problem. I looked in the Kaw owners manual and it said to push down on the center of the seat while turning the key clockwise to remove it. I tried that with no luck at all. Anyone know how to remove a stuck seat?
posted April 23, 2008 11:55 AM
Did you try giving it a quick jab downward in the center, or a slow push?
If the latch needs grease you might need to get a friend to lift up on the back while you push down., while having the latch turned to the unlock position.
SV1RIDER
posted April 23, 2008 12:00 PM
I tried both. I also tied the key with a wire so it would be in the open position and sat on the bike and bounced up and down. Not sure what else to do. I wonder if taking the seat off is covered under my extended warranty.
ghostman
posted April 23, 2008 12:24 PM
Make sure you turn the key fully a couple of times, then push down on seat.
You should here it click.
After that, try to open normally.
I'm There Whether You See Me Or Not.
SV1RIDER
posted April 23, 2008 12:32 PM
I just got back from sitting on it backwards and bouncing up and down while holding the key in the open position. (clockwise) No Click, nothing. I have pulled on it, pushed on it and pushed the middle while pulling the back up. No Click at all.
SV1RIDER
posted April 23, 2008 12:35 PM
Maybe at 140 I just don't weigh enough.
fury
posted April 23, 2008 04:34 PM
it shouldnt be that tough...
Push down with 1 hand and turn the key with the other.
If it dont work take her in and get it removed... (then fixed)
warranty who knows...
hardcoremass
Powerhouse
posted April 23, 2008 05:07 PM
Best bet would be to return to dealer and have them remove and repair. Could be faulty release mechanism?
07 zx14 (black), flies removed, BMC race filter, Muzzys M10, PClll, PC ignition module, RT ext, Muzzy lowering links, 40 shot spray
SV1RIDER
posted April 23, 2008 05:15 PM
I just got it off. I have had bikes before where the helmet lock was also the seat release and I thought this was like that also. I unlocked and removed the helmet lock and saw there was nothing behind it that could possible release the seat. I then looked around and found the correct place to put the key and the seat came right off as it should. I appreciate everybody's help anyway.
johnnyrocketzx14
posted April 23, 2008 05:45 PM
not sure i ever would have admitted that
07 ZX14
Brocks Sidewinder, Stretched, lowered, strapped,Drag seat, PCIII W/Hub, No flies, BMC, Speedo Healer, Muzzy NOS/Shifter,
1.41 60, 5.77 1/8th 8.89 1/4
  Ignore this member    Click here to visit JohnnyRocketZX14's homepage.
posted April 23, 2008 05:52 PM
great story
FIFTH
The Magnificent Bastard
posted April 23, 2008 06:12 PM
I feel MUCH better about not knowing if my bike had an oil cooler or not.....thanks for the boost.....
and just fyi....the key hole between the handlebars is when you want to start it..
SV1RIDER
posted April 23, 2008 06:45 PM
If that's the dumbest thing I do this year it will be a great year. Ha Ha
posted April 23, 2008 08:23 PM
LMFAO>>>
MJ
posted April 23, 2008 08:31 PM
Cold..............................................but funny lmao
ninja14
posted April 23, 2008 08:32 PM
I must be one of the few that read the owners manual............
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
SV1RIDER
posted April 24, 2008 06:29 AM
Actually I read it also, but the picture was kind of small and made it hard to tell where the seat lock actually was.
KikonZX14
Novice
posted April 24, 2008 07:16 AM
Well I must admit that it took me a while and a lot of exploring to find the right place to put the key and lift the seat........reading the manual will definitively save us a lot of time...
Feel the need for SPEED2007 ZX-14 Black with Red Flames (Helibars, Sliders, Yoshimura TRC Ti 4-2 Slip Ons, Fender Eliminator, Zero Gravity SR Windscreen, Custom Heel Guards , Speedohealer V4, Pazzo Levers -soon to come: Flies out / PCV w/A/T kit and later 16T sprocket)1990 Honda Steed (Japan model same as Shadow)1993 Kawasaki Vulcan EN 500 (gone as I trade it in for the ZX-14)Santiago, Chile, South America
fury
posted April 24, 2008 09:37 AM
lol
I lov it!!!!!
Twinkie!
Screeper
2008 ZX 14 Akros, PC, Filter
posted April 24, 2008 02:50 PM
Its important to know where to stick your key to get her off. I mean the seat off......... Your honesty is inspiring.
SV1RIDER
posted April 24, 2008 07:54 PM
It was really a simple mistake. If you have had sex with about 50 women and the place to stick your key was always pretty much in the same place and then you met one and it was hidden under her arm pit. None of you guys would find it either, especially in a dimly lit garage.
KikonZX14
Novice
posted April 25, 2008 04:30 AM
LMFAO SV1RIDER
cbmpjc
Lifetime Rider
posted April 25, 2008 09:17 AM
This was sooo funny and it made me sign up
I'm looking forward to reading and responding to more.
cbmpjc
KawaBonzai
Leader of the Back.
posted April 25, 2008 09:30 AM
Is the second key only for the 06?
On my 08 the helmet cables has two loops on each end, one bolted to the frame under the seat and another floating freely, but can be looped thru a helmet then to a latch.
To lock the helmet I pop the seat, loop the cable thru the helmet strap, fasten end on frame peg, put seat back on.
I'll have to inspect further.
...Bonza
2009 ZX-14 Candy Lime Green
07zx14blk
ZX6R, ZX9R,ZX12R,ZX14
posted April 25, 2008 07:34 PM
Don't eel bad but that is really funny, if it makes you feel any better...
3 weeks ago I pulled off my mud flap and threw in a couple of l brackets for the plate and a cool blue LCD light.
Before finishing I decided to keep the tie downs that were attached to the fender (always nice to have) drilled them out put them on and screwed everything on nice and tight.
It wasn't till the next day when I went to take of my passenger seat cover that I realized by putting on the tie downs without the fender they now sat exactly were I needed to put my key to release the seat (thou I could have gotten at the helmet lock no problem  ). I came dame close to breaking the plastic trying to pry them to the side so I could get the seat released so I could take them back off and move them around.
Cheers,
0.37513995170593 seconds processing time
