BIKELAND > FORUMS > ZX-14.com > Thread: Expert advice need on sub throttle sensor NEW TOPIC NEW POLL POST REPLY
Old Guy
posted April 16, 2008 05:00 PM
Somehow cracked mine. Probably while adjusting valves. Local shop is checking into it. The service writer gal couldnt even find a part # for it.
The manual on pge 3-76 says "Do not remove or adjust subthrottle sensor since it has been adjusted and set with precision at the factory."
Hmm...., Me thinks I'm screwed Holmes!. Anybody got ANY experience with the sensors on the Throttle bodies.
Thanks, TC
Living the good life...,
On a XZ !!!!!
Tsukigi stainless full system
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
ninja14
posted April 16, 2008 05:19 PM
If you are not getting a code - flashing dash....
Remove the flies and forget about it.....
If you need more - PM me.
2006 Turbo ZX-14.
2005 V-max 20th Anniv.
Old Guy
posted April 17, 2008 02:53 PM
PM sent.
Had a code before I safety wired it back together.
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
wrongway
posted April 18, 2008 10:13 AM
you may not be able to buy the sensor frorm the dealer, but you can buy them on ebay. Almost all the current kawasaki bikes use the same TPS and sub-TPS . I have picked up a few on ebay for under 10 bucks. As for setting them you need to us a volt meter and set it in the middle of the factory spec'd range.
I had to remove mine when I bored the throttle bodies and setting them is not a big deal.
Roy
Old Guy
posted April 18, 2008 10:43 AM
Thanks Gentlemen.
Will see if I can get one off ebay.
After a PM from Ninja14 it looks like I need to reset my throttle points on my map. My flies have been out the whole time and its most likely the particle throttle opening settings arent right on my custom map. In reality, as long as the sensor isnt throwing a code it wont affect the ECU or pcIII. So it is most likely needs a new map.
On a XZ !!!!!
pcIII w/custom map
NO freakin flies!!
GP suspension forks
Penske rear shock
Rich's custom seat
good stuff
0.40757298469543 seconds processing time
