BIKELAND > FORUMS > ZX-14.com > Thread: Just another Fender Elim. Kit. NEW TOPIC NEW POLL POST REPLY
KawaBonzai
Leader of the Back.
posted April 16, 2008 12:00 AM        Edited By: KawaBonzai on 16 Apr 2008 01:02
Yo!
Nothing special here, just what I did to eliminate the rear fender and relocate the plate on my ZX-14.
Goals ...
1. NOT drill a bunch of holes for wiring/mounting.
2. Keep plate up high as possible, and more towards the back.
3. Keep a clean install look.
4. Have proper lighting.
I started off by using the Speed Tactics bracket ...
... then for a frame and LED lighting combo, the Street Magic illuminated frame ...
(note the recessed mounting holes that use flush mounting hardware.)
After it was all put together ...
The wires for the LED frame are teeeeeny. They are I guess made to route through frames on Harley's or such. Made it very easy to conceal the wires. I drilled a teeeeny 1/16th hole right at the bend of the bracket and fed the wires up into the tail to connect to the stock harness. Even with kneepads and a flashlight you'd have to search hard to see the wires.
I did drill two holes above the plate slots to move the plate up on the bracket. The gap between the top of the frame and the bottom of the tail is about 1/6th of an inch.
There are 5 LED's under that top lip of the frame. They provide adequate lighting from above across the whole width of the plate.
Sweet and simple, under 50 bones.
... Bonzai
2009 ZX-14 Candy Lime Green
gilberjj
Friend of Fast
posted April 16, 2008 01:26 AM
real clean...... I want to see this compared to the muzzy kit. Thanks for the post.
wikidzx-14
posted April 16, 2008 08:35 AM
Where did you buy the bracket? I purchased a fender elim kit but it sat too far under the tail and whenlowering and extending I mashed my plate. This looks like a great idea.
Black 07 ZX-14, Stretched to 64", Lowered 1 1/2", Brocks SMEG, Flies removed, PCIII, Brocks Map, 200/50/17 rear tire, 16/43 gears, Heli Risers, Tobin Seat, Fender Elim,
KawaBonzai
Leader of the Back.
posted April 16, 2008 08:38 AM        Edited By: KawaBonzai on 16 Apr 2008 09:39
Hi there,
Google for the win ... "Speed Tactics" as mentioned in my post.
Speed Tactics
You can find his stuff oneBay too, but watch out for the shipping on eBay. Directly from his site was the best pricing I found. and he shipped FAST!
... Bonzai
0.21080017089844 seconds processing time
